GND Level of Blackbox has changed
Discussion in 'Controller Boards' started by Hans Bethge, Mar 26, 2021.
  1. Hans Bethge
    Hey there,
    I think I have changed by mistake the gnd potential of Blackbox somehow. Symptomes: Fan dosen´t rotate and i measure only ~10 V at Motor Pins and Tool-Pins. Flashing with frimeware still works. Is there anything I can do or change fuse or something or do i just have fried the electornic?
    Kind regards for your response
    Toolhead and Motor pins will NOT have 24v present on them! The Toolhead pins have a 0-10v output, and 5v PWM pins. motor outputs are the output of chopper style stepper drivers, not DC. Fans can stop spinning after some time (dust in the bearings, etc)
    Not finding 24v on those pins would not indicate a problem per-se rather a mistaken measurement strategy?
    So what's the root problem you were chasing down?
  3. Hans Bethge
    Dear Mark thanks for your respone. Root problem is: Motors dosen't move anymore. With tool i meant coolant sry
  4. Hans Bethge
    additionally: all firmeware settings were gone and this unlock button is not active anymore
    Is $4=1 (Enabled) In Grbl Settings?
    Measure PSU output with it not connected to BlackBox
  6. Hans Bethge
    $4 is enabeld.
    Power supply still has 24V. Is think i have crash the internal (Blackbox) voltage supply?
  7. Hans Bethge
    if i plug in the 24V i without serial connection, there no sign of live (LED etc.). Only via serial connetion i see the lights
  9. Hans Bethge
    Ok, thanks Peter. i wrote them
