Gcode
Discussion in 'CNC Mills/Routers' started by AmirSigns, Jul 14, 2019.
  1. AmirSigns
    AmirSigns New
    Hi guys.
    I’m beginner .
    1:When I go to gcode generator website to make gcode . It says unavailable please wait.
    2:when I going to set machine as home
    X and Y working bet noting happened for Z
    May you help me ? Thank you
  2. Alex Chambers
    More info please @AmirSigns. What machine, what controller? What control software are you using?
  3. Kevon Ritter
    Kevon Ritter Veteran
    No one will be able to help unless you provide some information about your setup.
    What CAM software are you trying to use?
    What CAD software are you using?
    What machine?
    What controller?
    What GUI program are you using to talk to the machine?
  4. AmirSigns
    AmirSigns New
    1: openbuild 1510
    2: controller: Xprov4
    3:im using open build softwars
    thank you
  5. Alex Chambers
    I can't help much with the Xpro @AmirSigns, but there are other people here who can. Is your machine the Lead 1510 or the Workbee? Do you have limit switches and are they normally open or normally closed. If you are using Openbuilds control have you set the configuration for your machine. Again I can't help much with that but your answers will be useful to someone who can.
