Gantry Belt Mount - What is going on in this photo?
Discussion in 'General Talk' started by Tazilla, Nov 20, 2015.
  1. Tazilla
    Tazilla New
    Here is a image that I captured of the V-Slot Nema 23 actuator from the IGES/STEP part library. The image shows the belt passing through two 9mm aluminum spacers. How exactly would you attach the belt to a spacer block gantry?
  2. Tazilla
    Tazilla New
    I think I may have thought of the answer... would you wrap the belt around the 9mm spacer and then use a belt clamp?
