G-code to Image outline in Sketchup/Sketchucam
Discussion in 'CAD' started by fwm891, Feb 22, 2018.
  1. fwm891
    fwm891 Well-Known
    Tele-outline-RH_sml.jpg I'm trying to generate a g-code path around an image (Telecaster guitar body shape) in SketchUcam. I thought I'd be able to do it the same way my text query earlier. But I can't get anything other than the whole image (includes background white areas) selected. attached a scaled small version if someone wishes to have a go...
    fwm891 and Gary Caruso like this.
  3. Gary Caruso
    Yes, like Peter, I describe it a bit more detailed here
    I didn't use sketchucam in this example though, there are many ways to do this. Recently i've starting using Estlcam because it handles complex shapes like gears better than sketchucam does.
    fwm891 likes this.
    Excellent tutorial Gary! Worth a watch too!
    Always easier to just find / draw a vector than converting a Bitmap to a vector though
    Vectors are optimized as its already path data. Bitmaps was designed for displaying on screens.
    New - Guitar DXF files has a few Guitar shapes
    fwm891 likes this.
  5. Gary Caruso
    Yes I agree, sometimes the image leaves you with thick vector lines that create strange and inefficient tool paths, fine for one offs or v-carving but not the best.
    Another way is to drop the bitmap on sketchup and draw over it, then you will have a truly clean drawing if none of the new DXF's Peter posted fit the need.
    fwm891 likes this.
  6. fwm891
    fwm891 Well-Known
    Thanks both - very helpful. I've downloaded a tele shape from Peters link but I'll have a go at my own file just to make sure I can do it!
