Fusion Post Processor - Spindle Delay
Discussion in 'CAM' started by JSuster, Aug 5, 2020.
  1. JSuster
    JSuster New
    I noticed that when the post processor for Fusion 360 outputs multiple files for different tools, the spindle speed up delay is missing on all but the first file. Assuming I remember, its not too hard to put in the G4 command. Just checking to see if it was something that was in process or known.
    Thanks,
  3. David the swarfer
    will fix...
  4. David the swarfer
    I believe I have fixed it, download the zip from OpenBuilds/OpenBuilds-Fusion360-Postprocessor and test it please, once you confirm all is ok I will do a new release
  5. JSuster
    JSuster New
    Looking at the g-code, this appears to have fixed the issue. I have not run any of the files to confirm there are no new issues.
    Thank you for the quick response/solution!
