Fusion 360 question
Discussion in 'CAD' started by Barry Danks, Apr 18, 2018.
  1. Barry Danks
    Barry Danks Well-Known
    I'm getting fairly good at Fusion 360, but I can't figure out why there is a line between sketches
    Drew sketch
    Extruded to upper dimension of channel
    Started another sketch to create channel 2 circles
    Since sketch 1 is snapped to grid I drew 2 line perpendicular to channel end
    Used trim tool to remove remainder of circles and lines outside channel
    Extruded channel
    Starter another sketch following existing object
    extruded to create cap
    No lines anywhere else, had issue before closed Fusion and started new drawing and still get a line
    What am I doing wrong? :)
  2. JohnnyOh!
    JohnnyOh! New
    You may have your sketches light bulb turned on. If you have to you can also use the combine feature to remove this line.
    Good luck,
    John
