FTDI driver issue w/ XPro V3 on OSX Sierra
Discussion in 'Controller Boards' started by Oddturkout, Nov 2, 2017.
  1. Oddturkout
    Can't seem to get ftdi drivers to work, I was able to connect to USB port and update the GRBL on the board earlier in the day and run the stepper motors using Universal G-Code sender.
    Figured I would install new drivers from ftdi:
    D2XX Direct Drivers
    Virtual COM Port Drivers
    Installed both and after I disconnected the XPro to add another axis stepper drive. When I connect the board back and launched Universal G-Code sender, I got the no serial ports found error.
    I can see in system information "FT231X USB UART" when ever is board is plugged.
    Anyone dealt with this? When I plug an Arduino DUE I can see
    /dev/tty.usbmodem1411 when I type "ls /dev/tty*"
    which is what I think I used to see when the XPro was plugged in.. not anymore,
    Any ideas?
  2. Dr.O
    Dr.O New
    I was coping with same thing
    You should uninstall drivers, remove any leftovers.
    Then restart
    Install virtual comport driver and restart again
    That's work for me
