Foiled on my holiday workbee 1010 build
Discussion in 'General Talk' started by BruceD, Jul 4, 2019.
Thread Status:
Not open for further replies.
  1. BruceD
    BruceD New
    Bummer, just discovered I am missing the front X axis plate...
  2. BruceD
    BruceD New
    A whole 4 day weekend lost just because of poor labeling and attention to detail....sigh....
  3. Mark Carew
    So sorry to hear this Bruce I can understand the frustration when you dig into a Build and there is a missing part putting the breaks on the build. Just want you to know that we will be taking care of this as soon as possible so that you can be up and running quickly. Again please accept our apologizes we have a great Team here but every once in a while a slip up like this happens.The Part Store Team will be reaching out to you soon.
    GrayUK likes this.
  4. BruceD
    BruceD New
    Mark, Thank you for the reply. I have watched the build video a couple more times and found that I am also missing the 4 main end plates the hold the main frame together and that the y axis motors mount to.
  5. Mark Carew
    Thank you for the update @BruceD I will be sure to pass this along as well.
  6. BruceD
    BruceD New
    Hello Mark
    I received the missing parts today, thank you. Unfortunately I have a new issue that I had to send the parts store a message about. I have found that the z axis end plates have an issue with the flange bearing mounting holes. I measured the bearings at .630 and the holes are .628, this is .002 too small. I checked the x and y mounting holes and they are fine.
  7. Kevon Ritter
    Kevon Ritter Journeyman
    The holes should technically be undersized, otherwise the bearings would just fall out. If truly is that big of an issue, just take some 320 grit sandpaper in your finger and lightly sand around the hole.
  8. BruceD
    BruceD New
    You clearly don’t have a good understanding of the issue, this isn’t a freeze the bearing and press in type of situation. The bearings are held in place by the locknut. Following the video instructions you are to slide the bearings into the holes in the end plate. The x and y axis are fine. .002 is a lot of sanding, I didn’t pay all this money to manufacture the parts myself. This is becoming very frustrating, 5 major parts missing, two more not made correctly and terrible labeling of parts. It will be a really good machine if I ever get it built.
  9. Mark Carew
    Hello Bruce
    I see you have already reached out to the Part Store with this issue and I will let the Team take it from there. They will work with you to get you the parts you need.
    It really is a great machine and there are a lot of folks out there who are up and running and having a great time. Don't lose the hope it is a diy machine that you will understand inside and out once you have it running.
    We wish you all the best with your build and look forward to seeing your projects.
  10. Kevon Ritter
    If you think the world of cnc will be all sunshine and rainbows, you have a lot coming. The missing parts is one thing, but expecting to never have to do any kind of finishing work is another. You're in for quite the reality check.
  11. Mark Carew
    Thank you for your help @Kevon Ritter
    Looks like all the parts are on the way to @BruceD at this point and Bruce is in direct contact with the Part Store Team so all should be good now.
    We do our best to keep the customer service related issues with customer service though the Part Store. We appreciate all part related feedback as it helps to ensure that the community at large is receiving only top quality OpenBuilds products so if you have any issues please feel free to reach out to them [email protected] The Part Store are a great Team and always work to ensure that part related issues are resolved as quickly as possible so that we can be sure to have everyone one up and running.
    p.s. the thread will remain open for information purposes
Thread Status:
