Finally finished with the new build in SW and was wondering...
Discussion in '3D printers' started by DarkAlchemist, Sep 12, 2015.
  1. DarkAlchemist
    DarkAlchemist Well-Known
    I am not sure how well this build will go in the real world but in the end you will still need 3 printed parts (the hot end holder and two belt holders due to the way things do not line up) and I haven't touched my piece of junk printer since May (too many odd issues) but I think I could squeeze out something enough to get on this build and make the parts better.
    Now when it is all said and done the bed only moves in Z (YAY, no more banding and taller prints are doable) and all wheels + vslot design. I tried to make it so you would not have to cut anything, or print anything, but alas you will have to cut 540mm * 2 and 410mm * 4 out of 3 1m long 20x20 plus print those 3 items I mentioned.
    Question I now have is I may be trying to over engineer this because my i3 rework was an absolute nightmare of a printer and I was tired of having to dial it in and spending 1k+ hours on it to dial it in to print ALMOST 1kg's worth of parts. No joy.
    My final mechanical parts price came to $548.18 Plus s&h which made my jaw drop and made me wonder about the above I mentioned.
    Lets say I have an L in 3 dimensions (a corner of a box) would I need 3 90 Degree Joining Plates in each corner to make it not wobble and be very stable/rigid or instead would 3 Cast Corner Brackets achieve the same level of rigidity/stablity ? My current design has both in all corners and I was wondering if both are needed or would one, and which one, would be enough?
    edit: Here is a picture of what I am talking about of one of the corners.
    #1 DarkAlchemist, Sep 12, 2015
  2. DarkAlchemist
    The price doesn't include the 3 endstop holders and I am still debating if I should just print some because I prefer the ones with the light so I can quickly see, at a glance, which ones are engaged.
    I wonder if I should post this on a thread of another designer so I can get a response from someone who surely knows the answer? hmmmm.
  3. Joe Santarsiero
    Joe Santarsiero OB addict
    Moved to 3d printers.
    I think the corner plates will do it for you. However, you could always order the cast angles later on.
  4. DarkAlchemist
    The cast angle just isn't going to be enough, right? I wonder if the cast corners would matter all that much?
    The single most expensive part on the BOM is - 25 90 Degree Joining Plate SKU: 610 $4.80ea - $120.00 whereas this 28 Cast Corner Bracket SKU: 490 $1.50ea - $42.00 in comparison is minute.
  5. Joe Santarsiero
    Ever think about two joining plates and one cast corner for some or all corners?
    Just a thought.
    Joe
  6. DarkAlchemist
    Well, not sure what that would be like looking at the picture above. Could you elaborate or draw something? X,Y,Z in each corner so I am not sure how two joining plates and 1 cast corner would work.
  7. Joe Santarsiero
  8. DarkAlchemist
    Is there a rhyme or reason to which ones to remove? I was thinking the ones in the front to back to keep due to that being Y and more mass is moving back and forth (more inertia due to that) so those need to be steadier but I am only guessing.
  9. Joe Santarsiero
    I'm Sorry. It's hard to determine the orientation you're speaking of. It may not matter.
    In general, I believe using any two plates will accomplish what you're trying to achieve.
  10. DarkAlchemist
    Lets see if more will chime in about this as I have no idea tbh. I sort of believe it but not 100% sold on it. At least I found out that my option of only one motor for Z was spot on as that has been the #1 issue on my current hunk of junk from day one. Prusa, et. al., and his 2 motors attached to the same stepper driver never ever sat well with me. My main concern is how well will my setup work and I will know that once I build it which is my fear to spend over 500 dollars and the <bleep> thing doesn't work, lol.
  11. DarkAlchemist
    I did the math and the savings using your method was $52.80. That still is a lot of dough for just the mechanical parts then when you add the electronics this is a hefty price tag of a self made printer.
    Alternate price - $495.38 for just the mechanical parts plus s&h.
