Fault on DQ542MA Stepper Motor Driver
Discussion in 'Motors' started by Sam Jones, Sep 7, 2018.
  1. Sam Jones
    Sam Jones New
    Hey,
    I'm using a Nema23 Stepper Motor with the DQ542MA Stepper Motor Driver and 24v (250watt) Power Supply.
    I've had the stepper motor working with no issues, controlled by a Raspberry Pi, start this morning after running the stepper motor through a few turns the Driver stopped sending power to the motor and both the red and green LEDs seems to flash at the same time, although the green led is less bright than the red one.
    The motor is receiving a weak intermittent power signal as you can turn the motor slightly in time with the blinking LEDs.
    Has anyone see anything like this before? Feels like the driver is knackered as nothing changed between it working and not working?
    Sam
  2. GrayUK
    Hi Sam.
    Can you make a copy of this post and send it to the Parts Store as well?
    Use their "Chat With Us" blue box in the bottom right
    There's a good chance they will know if this problem has occurred in the past.
    Gray
  3. Sam Jones
    Sam Jones New
    I've just done this now, thanks Gray.
  4. Mark Carew
    Thanks guys :thumbsup: The Part Store will get you back up and running quickly.
