extremely trusted!
Discussion in 'CNC Mills/Routers' started by Glenn67, Apr 13, 2018.
  1. Glenn67
    Glenn67 New
    How do things work one minute and not the next? I have a homemade CNC machine. I am using Fusion 360, Universal G code sender and xPro controller. My last problem was me not setting the proper machine home position. I confirmed it was working and the next day I tried to run a code. Nothing! G code sender goes into idle. If I try to jog the machine I get a message "unsupported command". I know it sees the port, if I unplug it I get a message. My baud rate is 115200. I tried to run a program with easel which has worked in the past but it won't work either. I tried another computer but same results. Is this an xPro controller issue or am I doing something wrong ...again?!? Any help is greatly appreciated.
    Glenn
