Expanding the z on the ox cnc
Discussion in 'CNC Mills/Routers' started by DarkPenguin, Oct 4, 2018.
  1. DarkPenguin
    DarkPenguin Well-Known
    So I'm thinking of doing this.
    Moving the 8020 y axis supports to the edge just outside of the router body. Then make a 2040 frame underneath that connects at the front and back supports. Place a few 2020 cross members. Spoil board goes on top of that.
    That should give me 80mm more z room than the default 61mm. Lead screw and 6020 for the z would need to be extended but that's easy.
    Everything bigger than 61mm would have to fit within the box defined by the 8020.
    If I wanted more space I could also by the bigger gantry plates. (which I could also do but I have a lot of the extrusion already.)
    Obvious problems with this?
  2. Kevon Ritter
    Kevon Ritter Veteran
    The only obvious issues are a reduction in rigidity and stability. Even hardwoods at max reach may bite back, but shouldn't be a problem if you properly plan the toolpath.
  3. DarkPenguin
    Good point. I've some ideas for that.
    The thing with this idea is that I'm hoping to add strength by creating the sub-frame under the current machine. Z axis is a bit, um, spindly.
