Error #33 on G03 with Blackbox
Discussion in 'Control Software' started by Sylvain Michaud, Mar 5, 2022.
  1. Sylvain Michaud
    All firmware are up to date...
    Using Hypertherm plasma but for this test machine are off. All parts of cnc are grounded and I make special attention in wiring ( shielded...)
    Using Sheetcam ( up to date ) for cam software and GRBL post processor recommanded in other post...
    See this video :
    and files,
    Need help please
    Best regards
    Error 33 means the Gcode the post created is invalid and thus does not constitute a valid Arc
  3. Sylvain Michaud
    Blackbox can make arc with I and J gcodes right ?
    With cam.openbuilds.com... I make same parts with fusion -> export to DXF ->open in cam.openbuilds ->make gcodes and no arc are inside GCODES ?
    #3 Sylvain Michaud, Mar 5, 2022
    Grbl supports valid Arcs yes. OpenBuilds CAM doesn't generate Arcs no, uses interpolated line segments, not as optimised, being a free, basic, entry level CAM (;
  5. Sylvain Michaud
    Do you have idea to help me with this ? I can't see what is wrong with my G03 X15.202 Y30.798 I-2.956 J-1.225 ? Decimal ? I change from 0.0000 to 0.000 and no change...
    Do you have website or link for helping me ?
    I have contact Sheetcam admin and wait for return :)
    Thanks for your help and VERY fast reply :)
    Haven't used SheetCAM in years, so I don't have a better post around myself. See Grbl problems - sheetcam.com though, discussion mentions arc errors toward end of page 1 with another Post available on page 2. Getting into editing the post if needed may also be helpful
