Engraver
Discussion in 'General Talk' started by stuart wallace, May 25, 2020.
  1. stuart wallace
    I used a diamond drag but for this. I’m reasonably happy with it, but some of the lines aren’t super straight? I ran this pretty quick. 90ipm. Would slowing it down help? I’m willing to say this is good enough but I wondered if y’all had any pro tips. Thanks!
    What kind of machine do you have it mounted to?
  3. stuart wallace
    Openbuilds lead 1010 with high z. Cheers
    Well, then it shouldn't be machine flex, how is the engraver mounted to the machine, if not perfectly rigid, that may be the source of the wiggle
    #4 Peter Van Der Walt, May 26, 2020
  5. stuart wallace
    Gotcha thanks. Maybe just tighten up the collet a bit? I may have not tightened it as much as I normally would because I knew the router would be off. Cheers
    Oh, mounted in the router.
    Well, give it a wiggle and see what deflects :)
    stuart wallace likes this.
