Engrave and cut in one Projekt - Eleksmaker A5
Discussion in 'Laser Cutters' started by osTblock, Oct 27, 2017.
  1. osTblock
    osTblock New
    Hello folks,
    i am new at the forum and have look for a way to engrave and cut in one step...
    Can you give me some posibiletys for this...?
    *sorry for the bad english*
  2. Kevon Ritter
    Kevon Ritter Veteran
    What kind of cutting? You can cut with a laser. Or do you want to engrave something that you can't cut with a laser? If so, then it's easier to just cut them on a milling machine, then place and engrave on another. Another option would be to put a laser next to a router.
    At the end of the day, you can laser with a milling machine, but you can't mill with a laser cutter.
  3. osTblock
    osTblock New
    ... I want to engrave with a Laser for example a photo, and cut with te laser around the outline of the picture so that i can take it out of the plywood!
    The laser is a 2.5W
  4. Ariel Yahni
    Ariel Yahni OpenBuilds Team
    What software are you using? In LaserWeb 4 I use an operation for raster engraving and then an operations for cutting the outline.
  5. osTblock
    osTblock New
    At the moment i am not shure witch i want to use. Benbox is just for playing..., with T2Laser i have problems with the arduino board to run the laser (maybe its my fault).
    I doesnt test laserweb until now...!
    I try tomorrow to run laserweb, i hope i can bring it to live with the arduino board...
    #5 osTblock, Nov 6, 2017
