Enclosures
Discussion in 'General Talk' started by nate campbell, Aug 22, 2015.
  1. nate campbell
    Can anyone recommend a good place to get cheap enclosures in Europe?
  2. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Can you be a bit more specific Nate :) ??
    Enclosures for the electronics or the complete machine or what ??
    Tweakie.
  3. nate campbell
    Foe electronics. I ended up getting a PC case which will work but not really what I wanted. It would still be nice to find a place that sells reasonably priced sheet metal boxes. For most electronics suppliers a biggish enclosure (500mm x 500mm x 150mm) seems to run in the $200-300 range...
  4. Rick 2.0
    Somewhere here on the forum is a nice little box made with 20x80 V-slot sidewalls and sheet metal top, bottom and ends but for the life of me I can't seem to locate it. It was over a year ago and 15,000 posts later it seems to have slipped into obscurity. Very economical and easy to build though. Anyone remember where it is?
  5. Hytech2k
    Hytech2k Veteran
    I found this one, not sure if it's the same one Rick...
    http://www.openbuilds.com/builds/another-mostly-stock-ox.2160/
    Rick 2.0 likes this.
  6. Rick 2.0
    Not the same one but the same idea. It's what I was hoping to get across.
