DuetWifi with DQ542MA
Discussion in 'Controller Boards' started by Adam Filipowicz, Apr 16, 2018.
  1. Adam Filipowicz
    Adam Filipowicz Journeyman
    Looking into connecting a DuetWifi conntector to DQ542MA Driver
    Hoping for some help, so i dont screw this up lol.
    Let me know if you guys see any issue with this setup.
    #1 Adam Filipowicz, Apr 16, 2018
  2. Adam Filipowicz
    Ok i am not sure whats up.. at first i wired up one.. seemed fine, but now after i wired up all three
    when i turn it on and try to move the steppers.. they Hold strong, but dont move.
    DQ542ma are being powered from one set of 12GA wires. and then split into three (one for each driver)
    every thing is mounted to a wood board.. could this be a grounding issue.
    Red light shows on DQ542MAs
    error code says
    Motor doesn’t run, but maintains holding torque
    Without input pulse signal
    Adjust PMW & signal level
    on DuetWifi firmware i have the driver configured like this
    M569 P5 S1 T5:5:5:0
    for pulse timings
  3. Gary Caruso
    disconnect "enable" maybe?
    Assuming the rest is connected correct.
    I think you need to power that breakout board with 5vdc? Or check that there is already 5Vdc on the small side headers..
    #3 Gary Caruso, Apr 30, 2018
  4. Adam Filipowicz
    well to make things worse.. lol it started working.
    now im more confused then ever..
  5. Gary Caruso
    Ok never mind then :)
