Dual Shaft Nemas
Discussion in 'General Talk' started by GrayUK, Jun 29, 2014.
  1. GrayUK
    Is it right that you could mount an Encoder to the rear shaft of a Dual Shaft Nema?
    Does that mean you would then have step feedback to the program?
    If so, is it straight forward?
    Or have I got it completely wrong?
    Which wouldn't be unusual.
    Gray
  2. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Hi Gray,
    I am sure you could do that but I am not sure it would serve a useful purpose for a stepper motor (servo's are an entirely different matter though).
    Stepper motors, assuming a properly constructed machine, do not loose or gain steps - they only move the commanded amount so the driving software always knows the exact position of each motor.
    Tweakie.
  3. GrayUK
    Thanks for that Tweakie.
    OK then. I'll just stick some sound dampers on the ends then.
    Gray
  4. Tweakie
    Moderator
    Nice one my friend. :)
    Their not 'sound dampers', they are 'mid-band resonance dampeners' - look real cool. :cool:
    Tweakie.
  5. GrayUK
    Well I'll go to the foot of our stairs. :zipit: Silly me. Of course they are. Well, I know what I meant. :p
    Do they actually do anything significant? :confused: I could always stick a flag or something on the Z axis. :ROFL:
    Gray
  6. Tweakie
    Moderator
    I know you knew - just pulling your leg. :)
    Perhaps best to just stick a flag on it - I think most of the leading stepper driver chips nowadays incorporate pulse-shift to counteract and suppress the resonance when it is detected. I think Gecko were the first to incorporate these chips in their products but others were quick to follow.
    Tweakie.
  7. GrayUK
    Now I didn't know that!!
    Does it work, make it a bit quieter? I didn't realise the answer would lie in the Driver.
    Well well.
    Gray
  8. Brian Slee
    Brian Slee Well-Known
    I hate to be contrary with Tweakie but the dual shaft stepper motors are specifically designed to mount an encoder on the back side for closed loop feedback. In some applications like flight control systems the steppers are preferred to the servos because they actively maintain position vs synchros which require a dampening system and braking system.
  9. bit53b
    bit53b New
    Hey, I stuck a flag on my Z-Axis - turned out well ;)
  10. Tweakie
    Moderator
  11. Tweakie
    Moderator
    Good point Brian and I am pleased you made it. :thumbsup:
    I am sure that there are many out there who do use closed loop stepper motor systems with their CNC machines and are extremely pleased with the result but I do wonder if it is really necessary. For me open loop rules. :D
    Tweakie.
  12. Brian Slee
    Hey Tweakie :)
    I agree...for CNC apps I think open loop is preferable in a lot of (if not most) cases. I was thinking more along the lines of other uses for steppers like in aviation or process control systems where they may be used because of their active position holding capability.
    #12 Brian Slee, Jun 30, 2014
