Drivers
Discussion in 'CNC Mills/Routers' started by GrayUK, Sep 13, 2014.
  1. GrayUK
  2. Robert Hummel
    Robert Hummel Custom Builder
    Moderator
    Yep same chip I'm using :)
  3. GrayUK
  4. GrayUK
    Additionally. With these powerful Drivers available at such low prices, why would you bother with the all in one composite boards? i.e. Drivers and controller in one?
    Is it because the likes of Arduino, Grbl, and such, can't supply such high amperage, that you don't get Arduino, or similar, stand alone controllers?
    Or have I just got it completely wrong?
    Gray
  5. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Now there's a coincidence, I have just ordered one of those HY drivers from China (for my B axis) £9.93 inc. postage. :)
    I have no idea if they are any good or not but I will know in a week or so.
    Tweakie.
  6. GrayUK
    Keep me posted. You know you could have got it from Devon??? :D
  7. Tweakie
    Moderator
    Hi Gray,
    The HyCNC driver has arrived, and has been tested. It works well at 48 Volts driving a 5 Amp stepper but, as suspected, it does require fan-assisted cooling to keep the heat-sink temperature down below 60 deg.C.
    I should point out that there have been some bad reports on the HY-DIV268N-5A but, so far, my experience is all good.
    Tweakie.
  8. GrayUK
    Actually, after a closer look at the site, I have a sneaky feeling it isn't in Devon. It has a Chinese feel about it. No address. No phone number.
    You know what I mean.
    Still the promised delivery dates are quite quick, so I don't really know for sure.
    We'll see.
    Gray
  9. offtrolley
    Hi Gray,
    read these threads first before buying:
    http://forum.planet-cnc.com/viewtopic.php?f=9&t=1107
    http://www.cnczone.com/forums/stepper-motors-drives/186930-tb6600-drive-ebay.html
    I believe that seller is in China but ships from Devon so there is no import duty. Items may take longer than usual. Thinking of getting the same drivers but having just had a burnt out board I'm more interested in quality so still investigating.
    Rob
  10. offtrolley
  11. Rick 2.0
    When you look at what else he sells (harem pants, anime wigs, ...) and the 53 negative feedbacks he has gotten in the last month, I think you have greater things to worry about than whether or not he is in Devon. CNC parts are not his business, merely something he found to sell.
  12. GrayUK
    Thanks. I hadn`t noticed the Thailand bit.
    Oh well too good to be true. Start saving again.
    Gray
  13. Tweakie
    Moderator
    I suppose we should all be aware that like most cheap stuff imported from China there are the genuine items and there are the rip-off or clone items, both may look identical from the outside. From my experience of these imported items you are never sure which you will get until it arrives I also allow for a 20% reject rate (the purchase price is good enough to still be in pocket when making this allowance).
    It is wise to dismantle and carefully, visually, inspect all electrical items, looking for bad solder joints and the odd unwanted shards of solder etc. before connecting power to the item. Anything that is bad or damaged is just binned – it does not make economic sense to return the item although, if bought via the bay, the seller will (more often than not) send another item if the first is damaged and you make a complaint.
    As for the HY-DIV268N-5A this has performed so well I have just ordered another 3 units from China. :)
    Tweakie.
  14. Tweakie
    Moderator
    Just in case it’s of any interest…
    This is the test rig and stepper motor the HY-DIV268N-5A has been driving at 48 Volts, 5 Amps (stop/start/reverse etc.) for a 48 hour test period.
    Tweakie.
