Dremel Flex Shaft Attachment
Discussion in 'CNC Mills/Routers' started by pmany, Nov 25, 2014.
  1. pmany
    pmany New
    So has anybody tried using one of the Dremel Flex Shaft Attachment (link to amazon)?
    They should be able to fit in most 1/8 collets.
    I have one for a off brand dremel that I use (non milling use) and the business end can be rotated through a full 360 degree rotation perpendicular to the motor. If the plastic cladding is removed it should be able to be threaded into an aluminum holder.
    Might be a good tool head for a 5 axis, with such a small profile.
  2. solvable
    solvable New
    Been thinking the same thing. Haven't built the machine yet though
