DQ542MA , Hot stepper when idle
Discussion in 'Motors' started by Adam Filipowicz, Apr 24, 2018.
  1. Adam Filipowicz
    Adam Filipowicz Journeyman
    I am using DQ542MA to drive High Torque stepper Nema 23
    I noticed that the stepper was hot after sitting idle for 1hr.
    I have switch 4 enabled, which should reduce idle current by 70%
    Current Peak is set to 2.84 Amps
    Should i reduce Peak amps?
  2. Gary Caruso
    Hot is when you cant keep your hand on them, so the question is how hot? :)
    Joe Santarsiero likes this.
