double side work?
Discussion in 'CNC Mills/Routers' started by Elhanan, Jan 30, 2017.
Tags:
  1. Elhanan
    Elhanan New
    hi.. is it possible to have c beam create a part from one side, reverse said part manually, and then have c beam machine another pattern (like grooves? ) on the other side?
  2. Darathy
    Darathy New
    It is ,you will either have to turn it and place it in exact same spot(you can use dowels ,have two or three holes in stock and bed outside the mill area and use dowels as guide so you place it in same place) or you will have to set 0.0.0 on a diferent location of the bed.
  3. Elhanan
    Elhanan New
  4. snokid
    snokid Journeyman
    a quick youtube video how to do it, just replace the line he draws with hard stops on x and y, or pins kind of up to you and how many you are going to make...
    Bob
    markinwi likes this.
  5. Joe Santarsiero
    Joe Santarsiero OB addict
    I'm a fan of those table clamps he had.
  6. Rick 2.0
    So how do we create cost effective knock-offs?
  7. Joe Santarsiero
    Find out who makes them so we can attempt to get some better images.
  8. Joe Santarsiero
    "They are Festool Clamping Elements - designed to work with their MFT surfaces.I machined similar holes directly into the MDF pallet and it seems to work pretty well.http://www.amazon.com/gp/product/B000JNEC1Q?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00When unlocked - you can slide the business end back and forth to adjust the length. Then with a cam action - underneath the center - a hard metal plate (up inside) bites against the silver rod to provide the clamping force. The silver rod is a softer material - and it can get little nicks from the biting action that hinder the sliding a bit if you use them in the same position all the time. If that happens - you can polish rods to buff out the nicks - and/or use the adjustment screws to adjust the clamping plate position. Not perfect - but very flexible and I do like them."
    $112 a pair!
    snokid likes this.
  9. snokid
    snokid Journeyman
    pricey but cool....
  10. Rick 2.0
    Sorry to keep hijacking the thread but came across these:
    GrayUK and snokid like this.
