Distance of centers in OpenRail!
Discussion in 'General Talk' started by Manuel García, Oct 19, 2015.
  1. Manuel García
    Can someone tell me what is the distance from shaft centers in OpenRails?
    In V-Slot are 40,30mm for 20x20 profile, but in OpenRails??
    Thanks!
    The plates are set up for 24,6 plus extrusion width. (i.e. 44,6 for 20mm extrusion etc.) I can't personally verify though. If you need something more accurate it is best to do a test setup and personally take measurements from that.
  3. Manuel García
    Oh, thanks!!! Also looks that VSLOT plates are 39,7mm and not 40,3mm like this plate.
    I'm confused about this difference (+-6mm).
    Regards
  4. Rick 2.0
    That's why I suggest a test setup. While the official line is 39,7mm, on the Extreme Solid V-wheels I get anywhere from 40,13 to 40,49 depending on the piece of rail the assembly is fitted to. (I checked with a 20x20 and the narrow edge of two 20x40s and a black 20x60) And while these are still within the range of an eccentric nut's adjustability it is best to start with something slightly under the final spacing. I typically use section depth + 20mm for the wheels noted above.
