Difference between ooznest x plate front and C-Beam® Gantry Plate - XLarge
Discussion in 'OpenBuilds Forum Help' started by pauna, Dec 5, 2017.
  1. pauna
    pauna New
    Hello
    Do you think there is a problem between these two plates holes?
    Openbuilds C-Beam Gantry Plate - XLarge The distance between two holes is 100.60 mm and the ooznest x plate front holes at 99.70 mm
    The difference is 0.9 mm
    Below are the photos that illustrate the problem I've made :(
    Eccentric Spacer is in the most remote position
    They say no problem.
    Thanks in advance
    You really won't have your answer until you fit them up to a specific piece of C-Beam. While it would seem that all C-Beam should be exactly the same in reality it is not. Different extrusion dies produce different results and while these differences may be ever so slight, they can occasionally be enough to make 99.7 too tight or 100.6 too loose.
  3. pauna
    pauna New
    Thanks for answer
    I think that in this case there will be no regulation.
    With my experience of 100.6 mm no problem, I use your product and without problems, it is regulated.
    I can not understand why it is necessary to change the size
    It would have been better if you had such a model, I would buy it.
