desktop water jet
Discussion in 'General Talk' started by snokid, Sep 13, 2016.
  1. snokid
    snokid Journeyman
    Ronald van Arkel and GrayUK like this.
  2. Ronald van Arkel
    That's cool, can't wait to see what pump they are using and build one for Openbuilds :).
    -Ronald
  3. Bad Sequel
    Bad Sequel Well-Known
    That is cool. Wish I had 4K too..
  4. snokid
    snokid Journeyman
    I can't remember which video showed the pump but it looks like a pressure washer pump.
  5. dddman
    dddman Journeyman
  6. Ronald van Arkel
    Well, I just looked at a pressure washer pump suggested by @snokid and it can do up to 3000PSI for 200USD, with a 0.2mm nozzle and a relative small mix tube it can do about 1/3kW of cutting power (so they say).
    I've been looking at the relative cheap heads, abrasives and circulation system and always found it interesting but the price of the pumps were enormous.
    -Ronald
    EDIT: Forgot to say that 200USD is without the motor ;)
    #6 Ronald van Arkel, Sep 16, 2016
  7. dddman
    dddman Journeyman
    Do you have the link for the pump (motorless)?
  8. Ronald van Arkel
    I mixed up PSI and BAR, my bad, so the pump can provide about 1/3kW and not 5kW. It was just a quick search on e-Bay. There are cheaper pumps that might be put parallel to get a higher water flow/pressure. It seems a NEMA56c motor is mostly used but I'm not sure.
    -Ronald
    #8 Ronald van Arkel, Sep 16, 2016
  9. Making Chips
    FYI,
    You may glean some info about the Wazer team's design approach from the developers college senior project video from a few years ago. They were using an air powered intensifier to generate ~6500psi. Here is a link:
    Cheers!
    KauaiMaker, GrayUK, snokid and 3 others like this.
  10. snokid
    snokid Journeyman
