DDBLDV1 Brushless spindle driver and mach 3
Discussion in 'CNC Mills/Routers' started by sasquatch437, Mar 15, 2015.
  1. sasquatch437
    Help please
    has anyone used this driver DDBLDV1 and the 400w spindle sold on Ebay, I'd like to know if you can use Mach3 to run the spindle thru the driver using g code and if it can what would i need to accomplish this? Any help will be appreciated and help me make a decision on what spindle to hang on my mill.
  2. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    The spec for that spindle driver says it accepts PWM input so that should work just fine with Mach3 where the code M3 /M4 will turn the spindle on M5 will turn the spindle off and Sxxxx will determine the spindle RPM.
    Tweakie.
  3. sasquatch437
    thank you looks like im going brushless
  4. sasquatch437
    i thinking of buying this driver and a 400w spindle would anyone have a wiring diagram to use this with mach 3 and one of the 5 axis breakout board sold on ebay
    thank you
