cutting to big
Discussion in 'General Talk' started by gazingm42, Mar 5, 2017.
  1. gazingm42
    gazingm42 New
    I trying to test my system and having some issues on the tinyg with chillipeppr cutting to big.
    I designed a small simple circle in inkscape and inported the svg to jscut. Did a simple cut
    outside line cut.
    Size is about 50mm or 2" across. But when you import the gcode into chillipeppr its dry cut
    wants to cut it about 500mm across.
    I have fooled around with this for about 5 or 6 hours double checking the settings etc.
    Just don't understand why the size from inkscape it not kept.
    Help.
    Please post the gcode
  3. gazingm42
    gazingm42 New
    Here a gcode...
    G21 ; Set units to mm
    G90 ; Absolute positioning
    G1 Z2.54 F2540 ; Move to clearance level
    ; Operation: 0
    ; Name:
    ; Type: Outside
    ; Paths: 1
    ; Direction: Conventional
    ; Cut Depth: 3.175
    ; Pass Depth: 3.175
    ; Plunge rate: 127
    ; Cut rate: 1016
    ; Path 0
    ; Rapid to initial position
    G1 X28.8064 Y61.0638 F2540
    G1 Z0.0000
    ; plunge
    G1 Z-3.1750 F127
    ; cut
    G1 X28.6212 Y61.0633 F1016
    G1 X28.4340 Y61.0615
    G1 X28.2517 Y61.0587
    G1 X28.0673 Y61.0551
    G1 X27.8808 Y61.0501
    G1 X27.6967 Y61.0440
    G1 X27.5153 Y61.0371
    G1 X27.3296 Y61.0287
    G1 X27.1465 Y61.0193
    G1 X26.9636 Y61.0089
    G1 X26.7810 Y60.9975
    G1 X26.6009 Y60.9853
    G1 X26.4168 Y60.9713
    G1 X26.2349 Y60.9568
    G1 X26.0533 Y60.9408
    G1 X25.8719 Y60.9241
    G1 X25.6911 Y60.9060
    G1 X25.5128 Y60.8878
    G1 X25.3301 Y60.8672
    G1 X25.1524 Y60.8466
    G1 X24.9705 Y60.8243
    G1 X24.7932 Y60.8014
    G1 X24.6141 Y60.7773
    G1 X24.4356 Y60.7521
    G1 X24.2567 Y60.7257
    G1 X24.0789 Y60.6983
    G1 X23.9011 Y60.6698
    G1 X23.7259 Y60.6409
    G1 X23.5488 Y60.6106
    G1 X23.3718 Y60.5791
    G1 X23.1955 Y60.5466
    G1 X23.0218 Y60.5139
    G1 X22.8460 Y60.4793
    G1 X22.6708 Y60.4440
    G1 X22.4955 Y60.4074
    G1 X22.3210 Y60.3696
    G1 X22.1488 Y60.3318
    G1 X21.9751 Y60.2921
    G1 X21.8036 Y60.2523
    G1 X21.6306 Y60.2108
    G1 X21.4577 Y60.1682
    G1 X21.2875 Y60.1255
    G1 X21.1158 Y60.0811
    G1 X20.9443 Y60.0356
    G1 X20.7749 Y59.9896
    G1 X20.6045 Y59.9424
    G1 X20.4343 Y59.8939
    G1 X20.2664 Y59.8451
    G1 X20.0988 Y59.7956
    G1 X19.9299 Y59.7443
    G1 X19.7609 Y59.6919
    G1 X19.5948 Y59.6393
    G1 X19.4267 Y59.5850
    G1 X19.2621 Y59.5309
    G1 X19.0947 Y59.4745
    G1 X18.9304 Y59.4184
    G1 X18.7668 Y59.3615
    G1 X18.6004 Y59.3023
    G1 X18.4358 Y59.2423
    G1 X18.2750 Y59.1834
    G1 X18.1092 Y59.1209
    G1 X17.9489 Y59.0597
    G1 X17.7861 Y58.9965
    G1 X17.6251 Y58.9327
    G1 X17.4625 Y58.8672
    G1 X17.3027 Y58.8017
    G1 X17.1412 Y58.7343
    G1 X16.9842 Y58.6681
    G1 X16.8237 Y58.5990
    G1 X16.6644 Y58.5291
    G1 X16.5082 Y58.4600
    G1 X16.3500 Y58.3884
    G1 X16.1928 Y58.3163
    G1 X16.0376 Y58.2444
    G1 X15.8793 Y58.1692
    G1 X15.7254 Y58.0953
    G1 X15.5702 Y58.0196
    G1 X15.4170 Y57.9442
    G1 X15.2629 Y57.8667
    G1 X15.1089 Y57.7884
    G1 X14.9578 Y57.7105
    G1 X14.8041 Y57.6297
    G1 X14.6530 Y57.5494
    G1 X14.5024 Y57.4682
    G1 X14.3523 Y57.3864
    G1 X14.2019 Y57.3028
    G1 X14.0520 Y57.2185
    G1 X13.9047 Y57.1347
    G1 X13.7551 Y57.0480
    G1 X13.6096 Y56.9629
    G1 X13.4612 Y56.8748
    G1 X13.3167 Y56.7882
    G1 X13.1686 Y56.6978
    G1 X13.0254 Y56.6096
    G1 X12.8793 Y56.5182
    G1 X12.7366 Y56.4275
    G1 X12.5926 Y56.3353
    G1 X12.4508 Y56.2431
    G1 X12.3081 Y56.1489
    G1 X12.1661 Y56.0541
    G1 X12.0251 Y55.9589
    G1 X11.8862 Y55.8639
    G1 X11.7457 Y55.7664
    G1 X11.6086 Y55.6706
    G1 X11.4686 Y55.5713
    G1 X11.3302 Y55.4712
    G1 X11.1940 Y55.3721
    G1 X11.0579 Y55.2718
    G1 X10.9223 Y55.1705
    G1 X10.7874 Y55.0686
    G1 X10.6525 Y54.9655
    G1 X10.5199 Y54.8631
    G1 X10.3848 Y54.7570
    G1 X10.2537 Y54.6531
    G1 X10.1211 Y54.5464
    G1 X9.9906 Y54.4402
    G1 X9.8603 Y54.3333
    G1 X9.7297 Y54.2243
    G1 X9.6012 Y54.1161
    G1 X9.4732 Y54.0066
    G1 X9.3457 Y53.8967
    G1 X9.2182 Y53.7852
    G1 X9.0932 Y53.6749
    G1 X8.9670 Y53.5619
    G1 X8.8425 Y53.4494
    G1 X8.7173 Y53.3346
    G1 X8.5941 Y53.2203
    G1 X8.4722 Y53.1057
    G1 X8.3492 Y52.9889
    G1 X8.2293 Y52.8738
    G1 X8.1082 Y52.7559
    G1 X7.9888 Y52.6383
    G1 X7.8689 Y52.5187
    G1 X7.7521 Y52.4011
    G1 X7.6324 Y52.2789
    G1 X7.5171 Y52.1601
    G1 X7.4013 Y52.0392
    G1 X7.2852 Y51.9162
    G1 X7.1712 Y51.7940
    G1 X7.0576 Y51.6711
    G1 X6.9436 Y51.5464
    G1 X6.8318 Y51.4222
    G1 X6.7206 Y51.2972
    G1 X6.6091 Y51.1702
    G1 X6.4996 Y51.0442
    G1 X6.3909 Y50.9175
    G1 X6.2827 Y50.7900
    G1 X6.1752 Y50.6620
    G1 X6.0678 Y50.5319
    G1 X5.9611 Y50.4014
    G1 X5.8572 Y50.2726
    G1 X5.7523 Y50.1408
    G1 X5.6490 Y50.0097
    G1 X5.5456 Y49.8766
    G1 X5.4450 Y49.7455
    G1 X5.3431 Y49.6112
    G1 X5.2431 Y49.4776
    G1 X5.1440 Y49.3435
    G1 X5.0447 Y49.2073
    G1 X4.9469 Y49.0717
    G1 X4.8504 Y48.9360
    G1 X4.7536 Y48.7979
    G1 X4.6586 Y48.6607
    G1 X4.5644 Y48.5230
    G1 X4.4704 Y48.3833
    G1 X4.3787 Y48.2459
    G1 X4.2860 Y48.1050
    G1 X4.1946 Y47.9635
    G1 X4.1049 Y47.8230
    G1 X4.0165 Y47.6833
    G1 X3.9266 Y47.5385
    G1 X3.8405 Y47.3983
    G1 X3.7528 Y47.2530
    G1 X3.6678 Y47.1105
    G1 X3.5822 Y46.9650
    G1 X3.4986 Y46.8205
    G1 X3.4163 Y46.6770
    G1 X3.3327 Y46.5286
    G1 X3.2525 Y46.3838
    G1 X3.1709 Y46.2345
    G1 X3.0924 Y46.0887
    G1 X3.0142 Y45.9414
    G1 X2.9355 Y45.7903
    G1 X2.8595 Y45.6429
    G1 X2.7841 Y45.4941
    G1 X2.7092 Y45.3440
    G1 X2.6342 Y45.1911
    G1 X2.5621 Y45.0417
    G1 X2.4900 Y44.8898
    G1 X2.4186 Y44.7374
    G1 X2.3485 Y44.5848
    G1 X2.2794 Y44.4316
    G1 X2.2111 Y44.2779
    G1 X2.1443 Y44.1248
    G1 X2.0775 Y43.9691
    G1 X2.0124 Y43.8149
    G1 X1.9479 Y43.6592
    G1 X1.8842 Y43.5022
    G1 X1.8222 Y43.3468
    G1 X1.7607 Y43.1898
    G1 X1.7005 Y43.0336
    G1 X1.6406 Y42.8746
    G1 X1.5822 Y42.7163
    G1 X1.5245 Y42.5566
    G1 X1.4684 Y42.3986
    G1 X1.4127 Y42.2388
    G1 X1.3581 Y42.0778
    G1 X1.3053 Y41.9195
    G1 X1.2525 Y41.7577
    G1 X1.2009 Y41.5965
    G1 X1.1504 Y41.4339
    G1 X1.1008 Y41.2708
    G1 X1.0531 Y41.1106
    G1 X1.0056 Y40.9477
    G1 X0.9588 Y40.7811
    G1 X0.9144 Y40.6214
    G1 X0.8697 Y40.4547
    G1 X0.8265 Y40.2901
    G1 X0.7849 Y40.1271
    G1 X0.7435 Y39.9592
    G1 X0.7038 Y39.7953
    G1 X0.6645 Y39.6269
    G1 X0.6269 Y39.4621
    G1 X0.5903 Y39.2960
    G1 X0.5542 Y39.1276
    G1 X0.5197 Y38.9610
    G1 X0.4859 Y38.7900
    G1 X0.4539 Y38.6236
    G1 X0.4227 Y38.4557
    G1 X0.3922 Y38.2863
    G1 X0.3630 Y38.1174
    G1 X0.3345 Y37.9450
    G1 X0.3081 Y37.7781
    G1 X0.2819 Y37.6051
    G1 X0.2573 Y37.4372
    G1 X0.2334 Y37.2635
    G1 X0.2111 Y37.0923
    G1 X0.1897 Y36.9216
    G1 X0.1694 Y36.7491
    G1 X0.1501 Y36.5774
    G1 X0.1321 Y36.4029
    G1 X0.1153 Y36.2302
    G1 X0.0998 Y36.0577
    G1 X0.0851 Y35.8845
    G1 X0.0716 Y35.7113
    G1 X0.0592 Y35.5353
    G1 X0.0483 Y35.3613
    G1 X0.0381 Y35.1870
    G1 X0.0292 Y35.0128
    G1 X0.0216 Y34.8360
    G1 X0.0150 Y34.6610
    G1 X0.0097 Y34.4860
    G1 X0.0056 Y34.3082
    G1 X0.0025 Y34.1327
    G1 X0.0005 Y33.9572
    G1 X-0.0000 Y33.7786
    G1 X0.0005 Y33.6028
    G1 X0.0023 Y33.4245
    G1 X0.0053 Y33.2493
    G1 X0.0094 Y33.0737
    G1 X0.0147 Y32.8965
    G1 X0.0211 Y32.7217
    G1 X0.0287 Y32.5472
    G1 X0.0376 Y32.3704
    G1 X0.0475 Y32.1964
    G1 X0.0587 Y32.0224
    G1 X0.0706 Y31.8487
    G1 X0.0843 Y31.6729
    G1 X0.0988 Y31.5000
    G1 X0.1143 Y31.3275
    G1 X0.1311 Y31.1548
    G1 X0.1488 Y30.9826
    G1 X0.1681 Y30.8083
    G1 X0.1885 Y30.6366
    G1 X0.2098 Y30.4652
    G1 X0.2322 Y30.2942
    G1 X0.2555 Y30.1233
    G1 X0.2807 Y29.9506
    G1 X0.3061 Y29.7824
    G1 X0.3335 Y29.6105
    G1 X0.3607 Y29.4431
    G1 X0.3904 Y29.2711
    G1 X0.4206 Y29.1025
    G1 X0.4521 Y28.9335
    G1 X0.4844 Y28.7656
    G1 X0.5171 Y28.5995
    G1 X0.5522 Y28.4299
    G1 X0.5880 Y28.2622
    G1 X0.6248 Y28.0956
    G1 X0.6624 Y27.9290
    G1 X0.7008 Y27.7646
    G1 X0.7414 Y27.5962
    G1 X0.7816 Y27.4337
    G1 X0.8245 Y27.2655
    G1 X0.8669 Y27.1030
    G1 X0.9111 Y26.9386
    G1 X0.9573 Y26.7720
    G1 X1.0020 Y26.6133
    G1 X1.0500 Y26.4476
    G1 X1.0986 Y26.2843
    G1 X1.1471 Y26.1243
    G1 X1.1976 Y25.9617
    G1 X1.2492 Y25.7997
    G1 X1.3017 Y25.6387
    G1 X1.3556 Y25.4774
    G1 X1.4092 Y25.3194
    G1 X1.4648 Y25.1588
    G1 X1.5215 Y24.9993
    G1 X1.5784 Y24.8419
    G1 X1.6370 Y24.6826
    G1 X1.6965 Y24.5246
    G1 X1.7574 Y24.3661
    G1 X1.8184 Y24.2104
    G1 X1.8809 Y24.0537
    G1 X1.9436 Y23.8988
    G1 X2.0084 Y23.7423
    G1 X2.0742 Y23.5861
    G1 X2.1397 Y23.4334
    G1 X2.2075 Y23.2782
    G1 X2.2746 Y23.1263
    G1 X2.3447 Y22.9711
    G1 X2.4140 Y22.8205
    G1 X2.4854 Y22.6671
    G1 X2.5583 Y22.5142
    G1 X2.6302 Y22.3648
    G1 X2.7041 Y22.2140
    G1 X2.7790 Y22.0636
    G1 X2.8555 Y21.9127
    G1 X2.9317 Y21.7644
    G1 X3.0089 Y21.6166
    G1 X3.0876 Y21.4680
    G1 X3.1671 Y21.3201
    G1 X3.2469 Y21.1738
    G1 X3.3284 Y21.0270
    G1 X3.4099 Y20.8815
    G1 X3.4945 Y20.7339
    G1 X3.5776 Y20.5907
    G1 X3.6619 Y20.4466
    G1 X3.7490 Y20.3006
    G1 X3.8334 Y20.1609
    G1 X3.9230 Y20.0148
    G1 X4.0096 Y19.8751
    G1 X4.1006 Y19.7311
    G1 X4.1897 Y19.5917
    G1 X4.2809 Y19.4507
    G1 X4.3716 Y19.3123
    G1 X4.4661 Y19.1705
    G1 X4.5585 Y19.0334
    G1 X4.6533 Y18.8944
    G1 X4.7483 Y18.7573
    G1 X4.8440 Y18.6206
    G1 X4.9428 Y18.4820
    G1 X5.0381 Y18.3494
    G1 X5.1384 Y18.2117
    G1 X5.2367 Y18.0786
    G1 X5.3376 Y17.9437
    G1 X5.4384 Y17.8106
    G1 X5.5410 Y17.6770
    G1 X5.6424 Y17.5462
    G1 X5.7465 Y17.4139
    G1 X5.8506 Y17.2833
    G1 X5.9563 Y17.1523
    G1 X6.0609 Y17.0237
    G1 X6.1684 Y16.8939
    G1 X6.2766 Y16.7647
    G1 X6.3851 Y16.6369
    G1 X6.4938 Y16.5101
    G1 X6.6045 Y16.3829
    G1 X6.7122 Y16.2600
    G1 X6.8257 Y16.1322
    G1 X6.9388 Y16.0067
    G1 X7.0490 Y15.8856
    G1 X7.1661 Y15.7591
    G1 X7.2779 Y15.6392
    G1 X7.3939 Y15.5162
    G1 X7.5108 Y15.3941
    G1 X7.6274 Y15.2737
    G1 X7.7432 Y15.1553
    G1 X7.8638 Y15.0339
    G1 X7.9825 Y14.9158
    G1 X8.1018 Y14.7982
    G1 X8.2205 Y14.6824
    G1 X8.3439 Y14.5637
    G1 X8.4656 Y14.4482
    G1 X8.5865 Y14.3346
    G1 X8.7107 Y14.2191
    G1 X8.8359 Y14.1045
    G1 X8.9588 Y13.9928
    G1 X9.0853 Y13.8797
    G1 X9.2126 Y13.7672
    G1 X9.3378 Y13.6577
    G1 X9.4663 Y13.5467
    G1 X9.5943 Y13.4375
    G1 X9.7229 Y13.3288
    G1 X9.8522 Y13.2211
    G1 X9.9835 Y13.1129
    G1 X10.1143 Y13.0067
    G1 X10.2456 Y12.9011
    G1 X10.3805 Y12.7941
    G1 X10.5103 Y12.6923
    G1 X10.6449 Y12.5879
    G1 X10.7793 Y12.4850
    G1 X10.9151 Y12.3824
    G1 X11.0505 Y12.2813
    G1 X11.1867 Y12.1807
    G1 X11.3233 Y12.0812
    G1 X11.4602 Y11.9826
    G1 X11.6012 Y11.8825
    G1 X11.7384 Y11.7863
    G1 X11.8775 Y11.6897
    G1 X12.0188 Y11.5930
    G1 X12.1580 Y11.4987
    G1 X12.3015 Y11.4030
    G1 X12.4404 Y11.3113
    G1 X12.5857 Y11.2168
    G1 X12.7282 Y11.1251
    G1 X12.8725 Y11.0339
    G1 X13.0160 Y10.9437
    G1 X13.1625 Y10.8533
    G1 X13.3063 Y10.7657
    G1 X13.4551 Y10.6763
    G1 X13.6002 Y10.5902
    G1 X13.7490 Y10.5030
    G1 X13.8951 Y10.4185
    G1 X14.0452 Y10.3329
    G1 X14.1950 Y10.2488
    G1 X14.3416 Y10.1673
    G1 X14.4945 Y10.0834
    G1 X14.6451 Y10.0024
    G1 X14.7963 Y9.9219
    G1 X14.9479 Y9.8424
    G1 X15.1021 Y9.7626
    G1 X15.2540 Y9.6852
    G1 X15.4081 Y9.6080
    G1 X15.5631 Y9.5312
    G1 X15.7165 Y9.4566
    G1 X15.8725 Y9.3816
    G1 X16.0266 Y9.3085
    G1 X16.1856 Y9.2343
    G1 X16.3411 Y9.1632
    G1 X16.4991 Y9.0918
    G1 X16.6576 Y9.0212
    G1 X16.8145 Y8.9526
    G1 X16.9741 Y8.8838
    G1 X17.1351 Y8.8157
    G1 X17.2926 Y8.7499
    G1 X17.4546 Y8.6836
    G1 X17.6169 Y8.6181
    G1 X17.7759 Y8.5551
    G1 X17.9395 Y8.4914
    G1 X18.1026 Y8.4291
    G1 X18.2656 Y8.3679
    G1 X18.4277 Y8.3080
    G1 X18.5910 Y8.2488
    G1 X18.7559 Y8.1899
    G1 X18.9230 Y8.1317
    G1 X19.0868 Y8.0756
    G1 X19.2517 Y8.0202
    G1 X19.4196 Y7.9648
    G1 X19.5844 Y7.9115
    G1 X19.7531 Y7.8581
    G1 X19.9220 Y7.8058
    G1 X20.0891 Y7.7553
    G1 X20.2560 Y7.7055
    G1 X20.4264 Y7.6560
    G1 X20.5948 Y7.6080
    G1 X20.7675 Y7.5602
    G1 X20.9337 Y7.5147
    G1 X21.1084 Y7.4688
    G1 X21.2778 Y7.4248
    G1 X21.4475 Y7.3819
    G1 X21.6205 Y7.3392
    G1 X21.7940 Y7.2976
    G1 X21.9672 Y7.2572
    G1 X22.1391 Y7.2181
    G1 X22.3131 Y7.1795
    G1 X22.4859 Y7.1424
    G1 X22.6629 Y7.1055
    G1 X22.8364 Y7.0702
    G1 X23.0096 Y7.0359
    G1 X23.1882 Y7.0022
    G1 X23.3622 Y6.9702
    G1 X23.5387 Y6.9387
    G1 X23.7162 Y6.9082
    G1 X23.8935 Y6.8790
    G1 X24.0693 Y6.8508
    G1 X24.2473 Y6.8234
    G1 X24.4279 Y6.7969
    G1 X24.6047 Y6.7718
    G1 X24.7813 Y6.7477
    G1 X24.9629 Y6.7243
    G1 X25.1430 Y6.7022
    G1 X25.3205 Y6.6814
    G1 X25.5008 Y6.6613
    G1 X25.6840 Y6.6420
    G1 X25.8623 Y6.6245
    G1 X26.0436 Y6.6075
    G1 X26.2255 Y6.5917
    G1 X26.4094 Y6.5770
    G1 X26.5895 Y6.5635
    G1 X26.7713 Y6.5508
    G1 X26.9542 Y6.5391
    G1 X27.1371 Y6.5287
    G1 X27.3205 Y6.5193
    G1 X27.5062 Y6.5112
    G1 X27.6873 Y6.5041
    G1 X27.8714 Y6.4977
    G1 X28.0581 Y6.4929
    G1 X28.2402 Y6.4888
    G1 X28.4269 Y6.4863
    G1 X28.6121 Y6.4845
    G1 X28.7973 Y6.4840
    G1 X28.9824 Y6.4845
    G1 X29.1673 Y6.4860
    G1 X29.3520 Y6.4888
    G1 X29.5389 Y6.4926
    G1 X29.7205 Y6.4975
    G1 X29.9070 Y6.5036
    G1 X30.0906 Y6.5109
    G1 X30.2717 Y6.5188
    G1 X30.4571 Y6.5282
    G1 X30.6400 Y6.5386
    G1 X30.8226 Y6.5500
    G1 X31.0050 Y6.5627
    G1 X31.1871 Y6.5765
    G1 X31.3665 Y6.5907
    G1 X31.5506 Y6.6067
    G1 X31.7317 Y6.6235
    G1 X31.9126 Y6.6415
    G1 X32.0911 Y6.6600
    G1 X32.2735 Y6.6803
    G1 X32.4536 Y6.7014
    G1 X32.6309 Y6.7230
    G1 X32.8104 Y6.7461
    G1 X32.9918 Y6.7708
    G1 X33.1681 Y6.7957
    G1 X33.3444 Y6.8216
    G1 X33.5247 Y6.8493
    G1 X33.7025 Y6.8777
    G1 X33.8778 Y6.9067
    G1 X34.0548 Y6.9369
    G1 X34.2316 Y6.9684
    G1 X34.4084 Y7.0009
    G1 X34.5821 Y7.0337
    G1 X34.7599 Y7.0687
    G1 X34.9329 Y7.1038
    G1 X35.1058 Y7.1398
    G1 X35.2826 Y7.1779
    G1 X35.4548 Y7.2158
    G1 X35.6286 Y7.2554
    G1 X35.8000 Y7.2953
    G1 X35.9730 Y7.3367
    G1 X36.1460 Y7.3794
    G1 X36.3184 Y7.4230
    G1 X36.4879 Y7.4667
    G1 X36.6570 Y7.5114
    G1 X36.8308 Y7.5587
    G1 X36.9971 Y7.6047
    G1 X37.1699 Y7.6539
    G1 X37.3372 Y7.7024
    G1 X37.5072 Y7.7530
    G1 X37.6738 Y7.8035
    G1 X37.8404 Y7.8548
    G1 X38.0088 Y7.9082
    G1 X38.1770 Y7.9625
    G1 X38.3416 Y8.0166
    G1 X38.5089 Y8.0730
    G1 X38.6733 Y8.1292
    G1 X38.8369 Y8.1861
    G1 X39.0027 Y8.2450
    G1 X39.1681 Y8.3052
    G1 X39.3309 Y8.3651
    G1 X39.4932 Y8.4261
    G1 X39.6542 Y8.4876
    G1 X39.8183 Y8.5516
    G1 X39.9806 Y8.6158
    G1 X40.1391 Y8.6793
    G1 X40.3009 Y8.7459
    G1 X40.4625 Y8.8132
    G1 X40.6194 Y8.8795
    G1 X40.7792 Y8.9481
    G1 X40.9400 Y9.0187
    G1 X41.0947 Y9.0873
    G1 X41.2544 Y9.1594
    G1 X41.4101 Y9.2308
    G1 X41.5668 Y9.3037
    G1 X41.7236 Y9.3778
    G1 X41.8793 Y9.4528
    G1 X42.0329 Y9.5274
    G1 X42.1876 Y9.6039
    G1 X42.3408 Y9.6809
    G1 X42.4947 Y9.7591
    G1 X42.6458 Y9.8371
    G1 X42.7995 Y9.9178
    G1 X42.9506 Y9.9981
    G1 X43.1013 Y10.0794
    G1 X43.2514 Y10.1612
    G1 X43.4028 Y10.2455
    G1 X43.5508 Y10.3285
    G1 X43.6982 Y10.4124
    G1 X43.8488 Y10.4995
    G1 X43.9943 Y10.5846
    G1 X44.1427 Y10.6727
    G1 X44.2879 Y10.7598
    G1 X44.4350 Y10.8498
    G1 X44.5783 Y10.9379
    G1 X44.7243 Y11.0293
    G1 X44.8663 Y11.1193
    G1 X45.0121 Y11.2130
    G1 X45.1528 Y11.3044
    G1 X45.2966 Y11.3992
    G1 X45.4370 Y11.4929
    G1 X45.5778 Y11.5879
    G1 X45.7187 Y11.6844
    G1 X45.8572 Y11.7802
    G1 X45.9979 Y11.8792
    G1 X46.1333 Y11.9752
    G1 X46.2735 Y12.0763
    G1 X46.4088 Y12.1746
    G1 X46.5460 Y12.2757
    G1 X46.6816 Y12.3771
    G1 X46.8175 Y12.4799
    G1 X46.9501 Y12.5813
    G1 X47.0865 Y12.6869
    G1 X47.2178 Y12.7898
    G1 X47.3494 Y12.8942
    G1 X47.4825 Y13.0011
    G1 X47.6131 Y13.1073
    G1 X47.7434 Y13.2142
    G1 X47.8739 Y13.3232
    G1 X48.0014 Y13.4304
    G1 X48.1307 Y13.5409
    G1 X48.2592 Y13.6519
    G1 X48.3845 Y13.7611
    G1 X48.5117 Y13.8736
    G1 X48.6367 Y13.9856
    G1 X48.7627 Y14.0997
    G1 X48.8848 Y14.2117
    G1 X49.0096 Y14.3273
    G1 X49.1317 Y14.4421
    G1 X49.2534 Y14.5574
    G1 X49.3756 Y14.6747
    G1 X49.4957 Y14.7918
    G1 X49.6161 Y14.9107
    G1 X49.7324 Y15.0263
    G1 X49.8528 Y15.1477
    G1 X49.9712 Y15.2686
    G1 X50.0865 Y15.3875
    G1 X50.2023 Y15.5084
    G1 X50.3184 Y15.6313
    G1 X50.4327 Y15.7535
    G1 X50.5463 Y15.8764
    G1 X50.6611 Y16.0027
    G1 X50.7708 Y16.1241
    G1 X50.8831 Y16.2503
    G1 X50.9946 Y16.3773
    G1 X51.1030 Y16.5020
    G1 X51.2130 Y16.6300
    G1 X51.3222 Y16.7588
    G1 X51.4284 Y16.8856
    G1 X51.5358 Y17.0156
    G1 X51.6425 Y17.1462
    G1 X51.7464 Y17.2749
    G1 X51.8503 Y17.4052
    G1 X51.9549 Y17.5378
    G1 X52.0583 Y17.6709
    G1 X52.1589 Y17.8020
    G1 X52.2608 Y17.9364
    G1 X52.3608 Y18.0700
    G1 X52.4619 Y18.2071
    G1 X52.5582 Y18.3389
    G1 X52.6567 Y18.4756
    G1 X52.7535 Y18.6120
    G1 X52.8500 Y18.7497
    G1 X52.9440 Y18.8850
    G1 X53.0395 Y19.0245
    G1 X53.1345 Y19.1660
    G1 X53.2249 Y19.3016
    G1 X53.3184 Y19.4441
    G1 X53.4073 Y19.5810
    G1 X53.4990 Y19.7245
    G1 X53.5884 Y19.8660
    G1 X53.6760 Y20.0070
    G1 X53.7644 Y20.1512
    G1 X53.8508 Y20.2940
    G1 X53.9364 Y20.4378
    G1 X54.0207 Y20.5808
    G1 X54.1063 Y20.7288
    G1 X54.1873 Y20.8706
    G1 X54.2709 Y21.0189
    G1 X54.3517 Y21.1650
    G1 X54.4312 Y21.3100
    G1 X54.5114 Y21.4588
    G1 X54.5909 Y21.6095
    G1 X54.6669 Y21.7542
    G1 X54.7444 Y21.9046
    G1 X54.8206 Y22.0555
    G1 X54.8950 Y22.2048
    G1 X54.9689 Y22.3555
    G1 X55.0421 Y22.5071
    G1 X55.1132 Y22.6567
    G1 X55.1851 Y22.8101
    G1 X55.2554 Y22.9640
    G1 X55.3240 Y23.1149
    G1 X55.3923 Y23.2688
    G1 X55.4604 Y23.4250
    G1 X55.5257 Y23.5767
    G1 X55.5917 Y23.7339
    G1 X55.6557 Y23.8883
    G1 X55.7187 Y24.0433
    G1 X55.7822 Y24.2030
    G1 X55.8424 Y24.3554
    G1 X55.9039 Y24.5162
    G1 X55.9631 Y24.6729
    G1 X56.0215 Y24.8312
    G1 X56.0791 Y24.9910
    G1 X56.1353 Y25.1489
    G1 X56.1909 Y25.3087
    G1 X56.2450 Y25.4675
    G1 X56.2991 Y25.6303
    G1 X56.3512 Y25.7898
    G1 X56.4027 Y25.9511
    G1 X56.4533 Y26.1136
    G1 X56.5028 Y26.2767
    G1 X56.5506 Y26.4370
    G1 X56.5981 Y26.6008
    G1 X56.6445 Y26.7641
    G1 X56.6898 Y26.9280
    G1 X56.7339 Y27.0928
    G1 X56.7771 Y27.2574
    G1 X56.8188 Y27.4205
    G1 X56.8604 Y27.5891
    G1 X56.8998 Y27.7517
    G1 X56.9389 Y27.9183
    G1 X56.9773 Y28.0877
    G1 X57.0133 Y28.2523
    G1 X57.0492 Y28.4192
    G1 X57.0840 Y28.5873
    G1 X57.1175 Y28.7545
    G1 X57.1500 Y28.9239
    G1 X57.1815 Y29.0941
    G1 X57.2115 Y29.2612
    G1 X57.2407 Y29.4301
    G1 X57.2691 Y29.6026
    G1 X57.2955 Y29.7702
    G1 X57.3214 Y29.9396
    G1 X57.3466 Y30.1134
    G1 X57.3702 Y30.2838
    G1 X57.3926 Y30.4553
    G1 X57.4139 Y30.6265
    G1 X57.4342 Y30.7982
    G1 X57.4535 Y30.9701
    G1 X57.4716 Y31.1446
    G1 X57.4883 Y31.3150
    G1 X57.5043 Y31.4903
    G1 X57.5188 Y31.6628
    G1 X57.5323 Y31.8388
    G1 X57.5445 Y32.0100
    G1 X57.5556 Y32.1865
    G1 X57.5658 Y32.3605
    G1 X57.5744 Y32.5370
    G1 X57.5821 Y32.7120
    G1 X57.5887 Y32.8865
    G1 X57.5940 Y33.0616
    G1 X57.5981 Y33.2394
    G1 X57.6011 Y33.4149
    G1 X57.6031 Y33.5906
    G1 X57.6036 Y33.7689
    G1 X57.6031 Y33.9450
    G1 X57.6014 Y34.1230
    G1 X57.5983 Y34.2983
    G1 X57.5942 Y34.4738
    G1 X57.5889 Y34.6511
    G1 X57.5826 Y34.8261
    G1 X57.5749 Y35.0006
    G1 X57.5663 Y35.1748
    G1 X57.5564 Y35.3514
    G1 X57.5452 Y35.5251
    G1 X57.5328 Y35.7011
    G1 X57.5198 Y35.8721
    G1 X57.5051 Y36.0476
    G1 X57.4893 Y36.2203
    G1 X57.4723 Y36.3950
    G1 X57.4548 Y36.5650
    G1 X57.4355 Y36.7392
    G1 X57.4152 Y36.9109
    G1 X57.3938 Y37.0826
    G1 X57.3715 Y37.2533
    G1 X57.3481 Y37.4243
    G1 X57.3235 Y37.5949
    G1 X57.2973 Y37.7677
    G1 X57.2701 Y37.9376
    G1 X57.2430 Y38.1045
    G1 X57.2132 Y38.2764
    G1 X57.1830 Y38.4451
    G1 X57.1523 Y38.6117
    G1 X57.1195 Y38.7819
    G1 X57.0860 Y38.9503
    G1 X57.0514 Y39.1182
    G1 X57.0159 Y39.2848
    G1 X56.9788 Y39.4524
    G1 X56.9420 Y39.6163
    G1 X56.9023 Y39.7852
    G1 X56.8622 Y39.9510
    G1 X56.8218 Y40.1144
    G1 X56.7792 Y40.2820
    G1 X56.7367 Y40.4446
    G1 X56.6925 Y40.6089
    G1 X56.6473 Y40.7727
    G1 X56.6011 Y40.9371
    G1 X56.5536 Y41.1007
    G1 X56.5051 Y41.2632
    G1 X56.4566 Y41.4232
    G1 X56.4060 Y41.5858
    G1 X56.3545 Y41.7478
    G1 X56.3019 Y41.9089
    G1 X56.2491 Y42.0679
    G1 X56.1937 Y42.2304
    G1 X56.1388 Y42.3887
    G1 X56.0822 Y42.5482
    G1 X56.0253 Y42.7057
    G1 X55.9666 Y42.8649
    G1 X55.9072 Y43.0229
    G1 X55.8472 Y43.1791
    G1 X55.7845 Y43.3394
    G1 X55.7238 Y43.4916
    G1 X55.6590 Y43.6508
    G1 X55.5953 Y43.8052
    G1 X55.5310 Y43.9587
    G1 X55.4632 Y44.1164
    G1 X55.3974 Y44.2675
    G1 X55.3275 Y44.4242
    G1 X55.2592 Y44.5756
    G1 X55.1894 Y44.7280
    G1 X55.1183 Y44.8804
    G1 X55.0459 Y45.0326
    G1 X54.9730 Y45.1837
    G1 X54.9001 Y45.3328
    G1 X54.8241 Y45.4849
    G1 X54.7494 Y45.6328
    G1 X54.6722 Y45.7831
    G1 X54.5943 Y45.9322
    G1 X54.5168 Y46.0785
    G1 X54.4368 Y46.2274
    G1 X54.3563 Y46.3747
    G1 X54.2747 Y46.5215
    G1 X54.1937 Y46.6660
    G1 X54.1091 Y46.8136
    G1 X54.0276 Y46.9551
    G1 X53.9407 Y47.1027
    G1 X53.8566 Y47.2441
    G1 X53.7685 Y47.3897
    G1 X53.6821 Y47.5307
    G1 X53.5927 Y47.6744
    G1 X53.5046 Y47.8146
    G1 X53.4142 Y47.9559
    G1 X53.3222 Y48.0978
    G1 X53.2313 Y48.2365
    G1 X53.1376 Y48.3770
    G1 X53.0466 Y48.5124
    G1 X52.9506 Y48.6531
    G1 X52.8541 Y48.7920
    G1 X52.7596 Y48.9269
    G1 X52.6631 Y49.0630
    G1 X52.5635 Y49.2010
    G1 X52.4660 Y49.3348
    G1 X52.3674 Y49.4687
    G1 X52.2663 Y49.6038
    G1 X52.1655 Y49.7369
    G1 X52.0629 Y49.8705
    G1 X51.9615 Y50.0013
    G1 X51.8574 Y50.1337
    G1 X51.7517 Y50.2657
    G1 X51.6473 Y50.3953
    G1 X51.5427 Y50.5238
    G1 X51.4353 Y50.6536
    G1 X51.3270 Y50.7829
    G1 X51.2201 Y50.9094
    G1 X51.1101 Y51.0374
    G1 X51.0007 Y51.1636
    G1 X50.8892 Y51.2904
    G1 X50.7779 Y51.4153
    G1 X50.6659 Y51.5398
    G1 X50.5536 Y51.6632
    G1 X50.4401 Y51.7862
    G1 X50.3232 Y51.9111
    G1 X50.2097 Y52.0313
    G1 X50.0929 Y52.1535
    G1 X49.9763 Y52.2739
    G1 X49.8605 Y52.3922
    G1 X49.7413 Y52.5124
    G1 X49.6212 Y52.6320
    G1 X49.5033 Y52.7483
    G1 X49.3806 Y52.8677
    G1 X49.2613 Y52.9828
    G1 X49.1396 Y53.0983
    G1 X49.0146 Y53.2154
    G1 X48.8930 Y53.3285
    G1 X48.7693 Y53.4420
    G1 X48.6433 Y53.5560
    G1 X48.5183 Y53.6678
    G1 X48.3926 Y53.7793
    G1 X48.2646 Y53.8911
    G1 X48.1388 Y53.9998
    G1 X48.0096 Y54.1100
    G1 X47.8795 Y54.2198
    G1 X47.7515 Y54.3264
    G1 X47.6202 Y54.4346
    G1 X47.4894 Y54.5408
    G1 X47.3580 Y54.6465
    G1 X47.2262 Y54.7514
    G1 X47.0921 Y54.8565
    G1 X46.9585 Y54.9599
    G1 X46.8231 Y55.0633
    G1 X46.6900 Y55.1641
    G1 X46.5534 Y55.2662
    G1 X46.4172 Y55.3668
    G1 X46.2793 Y55.4671
    G1 X46.1434 Y55.5649
    G1 X46.0042 Y55.6642
    G1 X45.8650 Y55.7615
    G1 X45.7251 Y55.8588
    G1 X45.5864 Y55.9538
    G1 X45.4447 Y56.0496
    G1 X45.3052 Y56.1428
    G1 X45.1604 Y56.2380
    G1 X45.0179 Y56.3307
    G1 X44.8767 Y56.4217
    G1 X44.7302 Y56.5144
    G1 X44.5877 Y56.6038
    G1 X44.4411 Y56.6942
    G1 X44.2973 Y56.7818
    G1 X44.1498 Y56.8707
    G1 X44.0037 Y56.9574
    G1 X43.8549 Y57.0445
    G1 X43.7088 Y57.1291
    G1 X43.5574 Y57.2152
    G1 X43.4116 Y57.2975
    G1 X43.2592 Y57.3820
    G1 X43.1091 Y57.4641
    G1 X42.9585 Y57.5451
    G1 X42.8074 Y57.6256
    G1 X42.6557 Y57.7051
    G1 X42.5016 Y57.7849
    G1 X42.3497 Y57.8624
    G1 X42.1955 Y57.9396
    G1 X42.0418 Y58.0158
    G1 X41.8864 Y58.0915
    G1 X41.7325 Y58.1654
    G1 X41.5760 Y58.2396
    G1 X41.4190 Y58.3127
    G1 X41.2615 Y58.3848
    G1 X41.1056 Y58.4555
    G1 X40.9451 Y58.5266
    G1 X40.7901 Y58.5946
    G1 X40.6286 Y58.6642
    G1 X40.4685 Y58.7318
    G1 X40.3111 Y58.7976
    G1 X40.1490 Y58.8639
    G1 X39.9887 Y58.9287
    G1 X39.8257 Y58.9932
    G1 X39.6651 Y59.0557
    G1 X39.5003 Y59.1186
    G1 X39.3410 Y59.1788
    G1 X39.1742 Y59.2403
    G1 X39.0129 Y59.2987
    G1 X38.8470 Y59.3579
    G1 X38.6806 Y59.4158
    G1 X38.5168 Y59.4720
    G1 X38.3520 Y59.5273
    G1 X38.1841 Y59.5827
    G1 X38.0192 Y59.6360
    G1 X37.8506 Y59.6894
    G1 X37.6839 Y59.7412
    G1 X37.5145 Y59.7925
    G1 X37.3454 Y59.8428
    G1 X37.1772 Y59.8916
    G1 X37.0096 Y59.9393
    G1 X36.8386 Y59.9871
    G1 X36.6672 Y60.0336
    G1 X36.4975 Y60.0785
    G1 X36.3258 Y60.1230
    G1 X36.1539 Y60.1664
    G1 X35.9832 Y60.2083
    G1 X35.8097 Y60.2500
    G1 X35.6365 Y60.2904
    G1 X35.4645 Y60.3295
    G1 X35.2905 Y60.3681
    G1 X35.1178 Y60.4052
    G1 X34.9430 Y60.4420
    G1 X34.7673 Y60.4775
    G1 X34.5918 Y60.5118
    G1 X34.4160 Y60.5454
    G1 X34.2417 Y60.5774
    G1 X34.0644 Y60.6089
    G1 X33.8874 Y60.6393
    G1 X33.7101 Y60.6686
    G1 X33.5343 Y60.6968
    G1 X33.3563 Y60.7242
    G1 X33.1782 Y60.7506
    G1 X32.9989 Y60.7760
    G1 X32.8201 Y60.8001
    G1 X32.6408 Y60.8232
    G1 X32.4630 Y60.8453
    G1 X32.2809 Y60.8664
    G1 X32.1028 Y60.8862
    G1 X31.9202 Y60.9053
    G1 X31.7411 Y60.9231
    G1 X31.5600 Y60.9401
    G1 X31.3787 Y60.9558
    G1 X31.1965 Y60.9708
    G1 X31.0147 Y60.9843
    G1 X30.8298 Y60.9970
    G1 X30.6494 Y61.0084
    G1 X30.4665 Y61.0188
    G1 X30.2834 Y61.0282
    G1 X30.0998 Y61.0366
    G1 X29.9141 Y61.0437
    G1 X29.7322 Y61.0498
    G1 X29.5483 Y61.0549
    G1 X29.3614 Y61.0587
    G1 X29.1765 Y61.0612
    G1 X28.9938 Y61.0633
    ; Retract
    G1 Z2.5400 F2540
    ; Return to 0,0
    G0 X0 Y0 F2540
    M2
  4. Giarc
    Is there a chance you put the wrong distance in your steps/mm setting? For example, you want 1/8" microstepping and set your machine for that, but your board is actually set at 1/4 microstepping? I bet it is a simple fix like something in the settings. Also, calibration is simple to do and will get you cutting accurately. I just did it and the formulas are here: Lead Screw Driven Ox Derivative (850x1500) and I believe you can find them in the resources section.
    Although this you are cutting 10X larger than anticipated, so this may not be the case.
    #4 Giarc, Mar 5, 2017
  5. Giarc
    You probably already know this, and I do not know much about TinyG, but there may be a spot to put a jumper to set the microstepping.
    The CNC Shield I started with did not come with the jumper and I had to buy some separately. I needed one but I think I ended up with 50 due to them coming in bulk.o_O
  6. gazingm42
    gazingm42 New
    Performing several tests with the $1tr in tinyg I changed it from 1.25 to 6.685 it now travels with jogs
    correctly. Took me some time to test and trail to get the correct number. I will later to some micro adjustments
    when I get more time. But right now a 10mm is correctly reflected as 10mm on a metric measuring ruler.
    I moved the $2tr, $3tr and $4tr now it jogs correctly.
    GrayUK likes this.
