Cutting problem
Discussion in 'CNC Mills/Routers' started by pauna, Jul 6, 2019.
  1. pauna
    pauna New
    Hello. I have a problem, can not you tell me what should be caused by this, such a cutting, I think that the belt problem I bought but it is still on the way …
    I have never had such a problem, new cnc size 1750 mm x1750 mm workBee, X controller.
    Staff Member Moderator Project Maker Builder Resident Builder
    Loose belt, loose pulleys (check the setcrews and nb that one is on the motor flat, and tight!) or loose wheels/router mounts etc.
    Give things a wiggle, if it moves when it shouldnt, you know what to do
  3. pauna
    pauna New
    Everything I checked is nothing. One problem is left alone
    Thats a nonstandard size so I would expect some unplanned flex:
    Mitigation:
    - come up with improvements to stiffen the frame (add some steel, extra V Slot, many ideas here on the forum)
    - use proportionally lighter cuts (shallower passes) to compensate
    Alex Chambers likes this.
  5. Alex Chambers
    Alex Chambers Openbuilds team
    I would expect some flex in an X axis that long @pauna, but not that much! You need to be methodical - start with the router mount, X axis gantry plates, eccentric adjustment on both Z and X axes, X axis fixing to Y gantry plates. I see @Peter Van Der Walt has beaten me to the next bit of advice!
  6. pauna
    pauna New
    Do I think I'll add another C-Beam Linear Rail? The problem is probably caused by this
  7. pauna
    pauna New
    Hello, I also thought that I would face the problem. I have to find a way
  8. Alex Chambers
    One approach is to insert a steel "U" channel into the C beam, but if it is to work it needs to be a very good fit! Or, if you can fit it in, a steel plate on the front of the C beam. Also remember that steel+aluminium = battery = corrosion. This probably won't matter much if the fix works - the steel channel would be even more securely bonded to the aluminium C beam.
    Try searching the forum for things like C beam rigidity, workbee modified and any other phrase you can think of that might link to other people's solutions.
  9. Alex Chambers
    PS - I think the flex in the X C beam is your biggest problem and I couldn't be sure from your video, but it looked to me as though there was also some play in your Z axis/X axis gantry plates as well.
  10. pauna
    pauna New
    thanks. I'll try to find the forum. I will do several options at first and graphically and maybe I'll find a way out
  11. pauna
    pauna New
    #11 pauna, Jul 8, 2019
  12. pauna
    pauna New
    What do you think about this structure?
  13. Alex Chambers
    Are you planning to run the belt through the middle of that rectangular steel tube? How would you fix it to the C beam? U channel would make life easier. I'm not sure how much stiffness 2/3 mm aluminium would add, and the screws to fix it could clash with the gantry plates. It is a solution that doesn't involve re-designing the way the gantry plates are fitted.
  14. pauna
    pauna New
    You're right about aluminum. The place is almost no. Belts still leave me in the place. Steel squared will be split into one side 10 mm and then the side is 5 mm that puts the M5 bolt
  15. pauna
    pauna New
  16. pauna
    pauna New
    I did something like this ... not so great effect
  17. Alex Chambers
    Neat! Hope that fixes the problem.
    Alex. :thumbsup:
  18. pauna
    pauna New
  19. Alex Chambers
    Obviously not.
  20. pauna
    pauna New
    Good result I have a vertical pressure
  21. pauna
    pauna New
    More power is needed but this is a problem
  22. pauna
    pauna New
    Feed rate - 2500 mm / min
    Pluge rate - 1400 mm / min
    Depth per pass 4mm
    t's a better result but I do not like it too
  23. Alex Chambers
    What size bit @pauna? With the flex problems you are having you may need to go a bit shallower than 4mm.
  24. pauna
    pauna New
    Bit is amana tool 3/16inch
  25. pauna
    pauna New
    I have one more try, at this moment brought me belts 6mm
    Do you think old belts are under the scratch? Dual belts work
    #25 pauna, Jul 14, 2019
  26. pauna
    pauna New
    My CNC "workbee" has recently started weirdly cutting. Initially, I blamed the router because the sound changed during cutting. It turned out that there were no problems with the router. I do not know what to
    think
