Cutting printed Posters
Discussion in 'Concepts and Ideas' started by Siomosp, Nov 30, 2021.
  1. Siomosp
    Siomosp New
    Hi!
    I am thinking to build a machine based on OpenBuilds ACRO System (?) for fast cutting, printed posters, using drag knife
    The posters are printed on paper 120 mm width, 100 - 150 mm length.
    The print sizes are always 20*30, 30x40, 35*50, 40*60, 50*70 cm
    The position of print is always random on sheet.
    The perfect setup would be
    • Define the 5 cut presets, easily accessible from OpenBuilds CONTROL
    • Position the printings sheet under the machine
    • Position (dragging by hand) the blade at the upper left corner of one print, for example the 40* 50
    • Select a the 40*50 cut preset, perform the cut
    • Position (dragging by hand) the blade at another print, for example the 30* 40
    • Select a the 30*40 cut preset, perform the cut...
    Any input if it possible?
    If it is, any ideas about the setup?
    Thanks!
    Panagiotis
  3. Rick 2.0
    Dragging by hand is never a good idea. The power generated by the spinning motors will smoke your drivers. Always use the jog function to reposition.
    Siomosp and Peter Van Der Walt like this.
