Cutting linear rails - best method
Discussion in 'General Talk' started by Rob Mitchell, Dec 12, 2015.
  1. Rob Mitchell
    Rob Mitchell Well-Known
    Hello, first build about to go down. I don't have a metal cutoff chop saw. I do have a mitre saw, maybe I can use a cutoff blade?
    How about a hacksaw?
    What are you using?
  2. Steve Fox
    Steve Fox Well-Known
    The chop saw will work fine.
    Either use a fine toothed carbide blade or an aluminum cutting blade.
    I cut aluminum with a 60 tooth carbide blade quite often.
    Just take it slow, it spits aluminum sawdust all over everything.
  3. autox3d
    autox3d New
    mitre saw is perfect for cutting it. It is what the manufacturer of my extrusions uses and you will see same setup in shops that cut profile for aluminum window fabrication.
