Cut stainless steel with OX CNC
Discussion in 'CNC Mills/Routers' started by Jakobvj, Nov 14, 2016.
Tags:
  1. Jakobvj
    Jakobvj New
    Hi
    Does anyone know if its possible to cut 2mm stainless steel plate with the OX CNC?
    Regards
    Jakob
  2. snokid
    snokid Journeyman
    I'm sure it could be done.... But not really the right tool for the job....
    slow and light passes would be key to success...
    Bob
  3. Christian Knüll
    Hi,
    stainless steel works quite well with trochoidal milling - even rather soft machines can do it:
    Obviously the more rigid the machine the better - but it is surprising how well even very soft machines perform.
    Make sure to get a tool specifically for stainless steel. Tools for aluminum will work well at first but their thin and exposed cutting edges dull much faster.
    Christian
  4. Jakobvj
    Jakobvj New
    Thanks for all the replies :)
    I will give it a shot
  5. Paparich
    Paparich New
    Dear Jake, how did it go? Any feedback and experience you have would be highly appreciated! :)
