Custom build 80w Co2 Laser Cutter
Discussion in 'Laser Cutters' started by CChico, Dec 7, 2018.
  1. Satish Veda
    Hey CChico,
    How are things? How the build coming along?
    Thx
    CChico likes this.
  2. CChico
    CChico New
    Hey, as of the last update I honestly haven't done much on it at all. Since I had it working, I ended up switching gears into production mode and that's what I've been doing for the past 3 months or so. The laser is working great and it's going strong.
    However, I've been wanting to finish paneling this sucker so that I can take some decent pictures and mark the build as complete so my aim is to have it done by this weekend or next weekend at the latest if this heat wave hasn't killed me by then. I went ahead and finally finished putting the panels surrounding the laser tube but ran out of hardware so I wasn't able to finish the bottom storage area of the laser. The hardware should get here tomorrow, so that should let me finish both left and right sides of the machine, but I'm unsure on what to do at the front. Ideally, I want to use the very bottom of the machine for random storage but that would require me to make doors and I hadn't thought that far up ahead when I first started designing this and it's going to require me to get crafty, so that hopefully takes me only a few days to figure out.
    Thanks for checking in.
    Here's how the laser looks as of right now with the lights on and off and lid up and down.
    GrayUK likes this.
  3. Patto21
    Patto21 New
    Wow. Looks amazing. You have inspired me to build a laser.
    Any chance you can share your sketchup file of the unit please so I can get some sizes etc.
  4. CChico
    CChico New
    Hey, I went ahead and added the sketchup file to the files and drawings section. Hope it helps some. Let me know if you have any other questions.
  5. Patto21
    Patto21 New
    Thanks Chico Helped heaps. Ive ordered my Extrusion.
    Do you have a wiring plan at all.
    ali jah likes this.
  6. pedrofernandez
    pedrofernandez Journeyman
    Chico you mind sharing the pulleys used for the Y and X axis
  7. CChico
    CChico New
    Hey Pedro, let me see if I can find the listing. I bought them off of eBay from CLOUDRAY. They have a website you can order from but their shipping is pretty expensive and sometimes you can find cheaper shipping on eBay for the same item from the same company.
  8. pedrofernandez
    thats the mechanical set?
  9. CChico
    CChico New
    That’s correct. It was the mechanical set. I still had to come up with clever ways to mount them but they worked nicely.
  10. Mark Carew
    The latest update showing this bad boy complete WOW!!! One of thew most amazing builds I have ever seen, truly a work of art @CChico . Thank you for sharing your in depth build and for taking us on on this adventure with you.
    You have to know I am going to ask you for one of those awesome OpenBuilds glasses for the shelf of first! :thumbsup:
    Really nice job my friend, thank you again!
    Balu and Peter Van Der Walt like this.
  11. Balu
    Balu Well-Known
    This machine is so beautiful, I wouldn't even want to run it, but just look at it. :)
    CChico likes this.
  12. Russ Gratton
    Hi, Absolutely the Best I ve Seen, I have ordered the extrusion, But 1 Question How Many Corner Brackets are in the build????? Thanks
  13. Someone In Space
    I love this build!! What do all the buttons do (5 front, 3 sides)? Do you also have any wiring schematics?
  14. CChico
    CChico New
    The buttons on the front are left to right for the exhaust, water pump, air assist, red dot, and then the lights. I now have 4 buttons on the side and they are to turn on the machine, to turn the laser power on. The other two are to either turn the Y-axis on or the A-axis (rotary).
    Unfortunately I don't have a wiring schematic, I just did (and figured out) things as I went along.
    KE6MTO likes this.
  15. Someone In Space
    I plan to follow your build for my build. Any pointers? Can I DM you some questions?
    CChico likes this.
  16. ali jah
    ali jah New
    Amazing build, I've started my own build and now I'm at the point on installing the panels. Wanted to ask if you have a wiring plan so i check if i missed any components or any improvements i can make.
  17. Luis carvalho
    Hello Goodnight! your work is very beautiful! i have an 80w machine with 90x60 desktop. the machine was made of MDF by a manufacturer here in Brazil. however the machine has several problems Alignment resulting from the fact that it is in MDF, not counting the weight, something around 300kg. Considering this I'm thinking about changing the structure of the maqui and I found this build. My idea is to reuse all machine components with the exception of the rails as they need to upgrade and increase the working area to something around 110x60cm. If u or any other participant that made this build, Could you tell me if it's stable for recording, which is what I do most?
  18. CChico
    CChico New
    Hey Luis. What do you mean for recording? As far as stability the machine is solid as can be, nothing shakes and rattles. I have mounted cameras on it and ran jobs and the footage comes out good with no vibrations or anything like that. I’ve been using. This laser every day since I built it and I can honestly say that I have had 0 issues.
