Cube Corners and Eccentric Spacers
Discussion in 'General Talk' started by tjb1, Feb 3, 2018.
  1. tjb1
    tjb1 New
    Do the eccentric spacers fit into the cube corner? I see several places where wheels are attached directly to the cube corner but I can't see if they are also using an eccentric. I've found the hole on the cube spacer to be 7mm and the diameter of the eccentric spacer to be 7.11mm according to the STEP files so it appears they won't fit together.
    T
    They do indeed fit, export from Sketchup to STP may have introduced inaccuracy. You do need eccentrics on both sides
  3. crispin
    crispin New
    3 sides have the larger hole for eccentrics while the 3 sides opposite have the smaller, standard, non-eccentric hole. Most eccentric spacers fit easily but the occasional spacer may require convincing.
