Cube 3 Brand New in Box - Need PIN to Initialize
Discussion in '3D printers' started by Tronetix, Jun 13, 2023.
  1. Tronetix
    Tronetix New
    It was 2015, got a fresh Cube 3 to replace broken under warranty. Life happened, things got in way and now 2023, found the Cube 3 box, fresh, unused, unopened but can't get past the PIN entry to initialize. 3Dsystems is of course unresponsive and cubify is dead. So, does anyone have a work around to bypassing this initialization process? I am also wishing to modify as needed to refill the cartridges and there were some great hacks for that I see on these forums. But, getting past the PIN entry is a hurdle. I also have a new unused, uninitialized 3D Sense scanner I will need a work around for but I see there is another forum for that.
  2. ayrezxxx
    ayrezxxx New
    Tengo el mismo problema :(
  3. SKesa
    SKesa New
    Hello everyone, if you still need an activation pin, please write
