convert hobby cnc to 3d printer ?
Discussion in '3D printers' started by outofstep, Nov 13, 2015.
  1. outofstep
    outofstep New
  2. outofstep
    outofstep New
    Hi , im keen to make some architectural models amongst other things,
    bought this cnc machine from the guy who made it
    it makes a bit too much noise for me until i build a shed and get a quieter spindle
    also from looking at these forums i see that my machine has some problems and also 3d printers seem like they can do what i want without the noise
    At some point id like to get a better cnc going and though this machine hasn't got that much i can reuse so maybe it would be okay as 3d printer?
    on another thread i asked if i could reuse electrics and realised that it would be much simpler to get some new stuff
    so my plan is get- ramps board, drivers etc, heatbed, direct extruder, end stops, lcd
    and try to reuse atx power supply?
    can the standard ramps electronics run these nema 24 okay?
    will my MDF z axis, or bed axis catch on fire?
    will lead screws be too slow ? or possible to callibrate with standard software
    Alternative to buying these parts i could just buy a machine but not cashed up
    cheers in advance
    ben
  3. outofstep
    outofstep New
    problems with my machine-
    bed is bowed- but y rail itself is okay
    difficult to adjust bearings to rail gap
    guy who made machine used a design then built it bigger without re engineering it
    fair bit of play in machine - suprised that has been able to cut anything- usually cut quite slow, small increments
    noisey
    good things-
    lead screws, nema 24
    came with computer and cnc software all set up
  4. outofstep
    outofstep New
    (bit embarrassing putting this bit of junk up on this site - but gotta start somewhere!!!)
  5. outofstep
    outofstep New
    these photos of some work the cnc has done above look rough, especially with flash- i have tried to run jobs as fast as i could get away with so as not to annoy neighbours
  6. Flash22
    Flash22 Well-Known
    there are no pictures displayed !! you either have them set to private ov you need to upload them to photobucket to share them
    ah there is a issues with google another member had the same issue
  7. outofstep
    outofstep New
    thanks for letting me know! , i can see the photos
    they are hosted with google photos - thought i had it sorted
    cheers
  8. outofstep
    outofstep New
    ill try hosting photos with dropbox, all photos below are hosted with dropbox, hope they work
    #8 outofstep, Nov 13, 2015
  9. outofstep
    outofstep New
    question-
    is my machine too rough to convert to 3d print?
    will it catch on fire?
  10. outofstep
    outofstep New
    does this work?
  11. outofstep
    outofstep New
  12. outofstep
    outofstep New
  13. outofstep
    outofstep New
  14. outofstep
    outofstep New
  15. outofstep
    outofstep New
