Controller Board Suggestions please!!
Discussion in 'CNC Mills/Routers' started by Jonny Norris, Jan 25, 2015.
  1. Jonny Norris
    Jonny Norris Well-Known
    Hi there.. I'm looking for yet another control board after the original hyteckworks board supplied with my kit had a short between the USB connector and the board, and fried itself, though i wasn't overly happy with its 3v logic system anyway. I've recently purchased a "digital dream cnc ddumv1.05" which boasted 400khz processing, but ultimately got thrown in the bin after just 3 days of trying to get the thing to work.. loosing USB connection, spazing out randomly and the thing didn't understand arc moves!!! I should have done some research on it before purchasing, if i had i would have found out the manufacturer has shut up shop and not offering any support, and many others finding the same issues. Though you can still buy these on amazon!!!
    So having learnt my lesson.. thought id better get some advise on the matter. I need a mach3 compatible 5 axis USB or Ethernet board that is going to be reliable.. smooth, has good support, and runs on 5v logic.
    your suggestions here will be most appreciated. Thanks
    Jon.
  2. GrayUK
    Sorry you've had really bad luck with the electronics. :cry:
    I reckon this has got to be the way for you to go: :thumbsup:
    http://www.planet-cnc.com/index.php?page=hardware
    It ain't cheap, but ask anyone, and they'll tell you it's reliable, and works really well!!
    Tie it up with a good set of Drivers, and that's it! :D
    SIMPLE :thumbsup::thumbsup:
    Gray
    Jonny Norris and pmany like this.
  3. Nick W
    Nick W Well-Known
    I have been procrastinating on which controller to use. I have always looked over the CNC USB Controller because of cost. I wanted to try out the Smoothie Board but router specific software support is lacking. But after looking at the planet cnc site, they have documented everything I was looking for. Homing procedure, tool length, etc. I just pulled the trigger on a MK3/4. Now I just need to pick up some drivers and motors. yeah, motors.... those would be helpful.
    GrayUK and Robert Hummel like this.
  4. Jonny Norris
    Nice cheers bud, and half the price of the smooth stepper. :) and liking the additional modules they do for it.
    Only thing that seems is odd. Why the jump between 4axis and 9axis?
    Another thing is they have mixed the input and output connectors, I prefer them to be on opposite side of the board but, other than that it, quite impressed. So cheers grey.
  5. Jonny Norris
    Cheers grey, but can't see on their site, are these mach 3 compatible?
  6. Jonny Norris
    Ahh i see, based on a grbl controller. That's a shame.
  7. SVK
    SVK New
  8. Gerry
    Gerry New
  9. Jonny Norris
    Thanks, no your input is most welcome and needed.
    Thanks for the links, haven't had a chance to do any real comparisons as yet but i will be soon, but pmdx have outlined the issues with usb, and having experienced buffer issues. I think it may be time to build a dedicated pc and use a parrallel port. So Most helpful. Cheers
    SVK likes this.
  10. Jonny Norris
    Thank you for the links, the usb to parrallel port converter would indeed be an option. Though svk has kindly posted a link to pmdx, that has opened my eyes to a few of the issues with usb in general, so now thinking of avoiding using usb otherwise a good solution.
    I'm not so sure planet Cnc boards are designed to avoid using mach 3 simply just have a different architecture that requires a grbl based controller instead. They are actually almost identical to Pibot, though you can get Pibot now at a fraction of the cost of planet CNC. I actually have one of these, and they are very neat, but unfortunately for me personally, I don't feel I get the same use ability and control options with its grbl controller as I do with mach 3. Call me old fashioned, but i also prefer to stick to what Im familiar with which may be clouding my judgment somewhat.
  11. SVK
    SVK New
    Hi Jonny,
    I'm glad that my post was helpful :)
    I see that you are experienced user and went through some issues already.
    I'm planing to use Laptop with parallel port(not best but) PMDX-126 breakout board in combination with smooth stepper will work according to PMDX site.
    Any recommendation for smooth stepper ?
    Would you recommend me to buy this PMDX-126 ?
    (I know you didn't run this combo but I have spent some time searching and I feel like I'm running in circles)
    Thank you very much and good luck
    #11 SVK, Jan 28, 2015
  12. Jonny Norris
    Haha experienced with issues yes but very much a novice. And running in circles, I know the feeling!!
    The pmdx-126 does sound good, and Thinking I may follow suit. But am I not right in thinking you only need the smoothstepper module for usb and Ethernet connection? Cheers
    Jon.
  13. SVK
    SVK New
    Smooth stepper is apparently needed with PMDX-126. I'm new to all this so I'm just going by what I was told at MyCNCuk.
    I have placed order for purelogic's PLMC-E4 which is BOB + Smooth stepper in one unit.
  14. Jonny Norris
    Have you got a link to that board? Can't find anything on it in google.
  15. SVK
    SVK New
  16. GrayUK
    No chance of English I suppose?
    Gray
  17. SVK
    SVK New
    Yes they have English instructions. Right click on website and choose translate. Then beside the product you have small arrow downwards(drop down menu) click on that and last two files are in English.
  18. GrayUK
  19. Jonny Norris
    Finally taken the plunge and bought and bought a uc300 motion controller from cnc4you and thier breakout board
    http://www.cnc4you.co.uk/UC300-USB-Motion-Controller
    And
    http://www.cnc4you.co.uk/Breakout-B...d CNC Stepper-Motor-5-Axis-Spindle-Relay-HG08
    With the idc to lpt lead to link the boards, came in a £186 total.
    Went for this one after speaking to cnc4you, he's backing this product with a decent guarantee and seems very helpful, also has a pretty good manual with diagrams in good not broken English which makes a change :)
    Fingers crossed I have more joy with these!!
    Will keep you posted
  20. GrayUK
    Hi Jonny
    Yes, please do keep us posted. Still not sure about the USB CNC board.
    I have no problem with using Mach3, so a workable, and reliable, alternative might be good.
    Can you specify any main pluses with this board yet, or shall we wait?
    Gray
  21. Jonny Norris
    No I know what you mean about usb, I am skeptical myself, I think I'd have preferred Ethernet. But in my experience now I feel there's alot of boards out there and all very much the same, what stood out with the uc300 was not so much the board, yes it ticked all the boxes, for me now what makes a product good, having been stung before is, that the seller and manufacturer are offering support for it, and standing by it as a reliable product.
    Having made some calls to uk cnc part merchants, one thing they all seem to be stringent on is to "avoid Chinese boards" and having had two myself, I can agree.
    These boards should turn up tomorrow, so will give you an update of how they go over weekend bud
    #21 Jonny Norris, Feb 5, 2015
    GrayUK likes this.
  22. Jonny Norris
    Right, at first glance, I am very, pleased with both boards.
    Some of the things I like:
    Motion controller:
    Uc300 Auto installer package downloadable from website installs up to date driver with firmware update for the board, with a couple of clicks, it installs the driver and mach 3 plugin, then on opening mach 3 with the plugin, advises you of the firmware update and flashes with new software. Very easy and pain free installation.
    Mach 3 Plugin has a very useful settings and monitor app, tells you exactly what ports and pins are being used, so can simply be transferred to Mach 3 ports and pins setting, really clear and easy! Uc300 analogue inputs can also be configured here. App also monitors the buffer, which is good. And has an error count!
    Also has index prescale setting in plugin config for use with encoders. Very useful!
    The price! It seems here I have a board capable of 6 axis, for less than many of the other 4+ controllers. With 49 digital inputs, 36 digital outputs, 2analogue inputs and 2 anolgue outputs, makes this board massivly flexible and wiring of potentiometers for feedrate for example, easy.
    Breakout board:
    Excellent quality 10mbps optocouplers
    Power supply optical isolation, very desirable.
    Onboard logic chip to filter input noise
    5axis
    pins are defined in Mach 3 ports and pins, so you are able to define which bob output controls which ever stepper driver. Which is a bigie for me, means no crossing output wires to stepper drivers!!! Fantastic!
    Finally! The excellent literature that can be found on both boards on the cnc4you website, is a vast improvement over that of previous boards.
    These are just some I'm sure of the bits I like, but for a more technical run down of the boards, if you look on the cnc4you website you will notice these boards supports pretty much every function you'd expect.
    And what I have noticed is the manufacturer of the uc300 has listed the bugs corrected in recent plugin updates, which in my opinion is s good sign that the board still has a good level of support.
    Next to cut a cycle , but so far having run an test cycle and monitored uc300 plugin, had no errors, buffer working well, and no drop of usb connection!!! So feeling optimistic!
    http://www.cnc4you.co.uk/Breakout-Board-and-PSU's/Breakout board CNC Stepper-Motor-5-Axis-Spindle-Relay-HG08
    #22 Jonny Norris, Feb 5, 2015
    GrayUK likes this.
  23. Jonny Norris
    Neat connection with lpt lead
  24. Jonny Norris
    1031 input functions in total!
  25. Jonny Norris
    Pins monitor :)
    Also has update plugin button :)
    #25 Jonny Norris, Feb 5, 2015
  26. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Just a thought but you may want to change that last picture which indicates you are using a pirate software license for Mach3 :duh:
    Tweakie.
    Atomist likes this.
  27. Jonny Norris
    Lol..That's my real name :)
    Infact thats a license that came with the last board I purchased. That for some odd reason wouldn't run without it. But will revert it back to my license. Cheers for pointing it out.
  28. Saint Billy
    A long time since but just wondered how you are getting on with the U300 and HG08. I have just ordered the same setup.
  29. Lodds
    Lodds New
    Very long time since this thread was started so apologies for waking it up.
    I'm considering purchasing from PlanetCNC but have doubts about the level of support I would get post sales. Being a newbie I have a number of questions that they don't answer.
    Wondering what people make of PlanetCNC, has anyone returned anything or had problems that needed them to resolve.
    What are your thoughts on PlanetCNC as a company?
