Control software for Linux computers CNC ROUTER LASER
Discussion in 'General Talk' started by Dontheone, Oct 31, 2019.
Tags:
  1. Dontheone
    Dontheone New
    I use Debian Linux for my computers. Does any of your software controllers use Linux operating systems? I am new to CNC devices so I will need to get some tutorials if available.
    I am now desiging a larger table top design OX type machine. I will be using the top of my assembly table for the base. It is 97" x 49" x 1" contractor size particle board. I built a honey comb top 5" thick several years ago and it is very flat and stable. It is very strong. I plan to use 1/2 " x 3" aluminum strap on the sides of the top for the side rails but have not found a source yet for the longer screws. Can you get longer 8mm screws from your suppliers? I will probably use 2 20x80 pieces for the gantry cross top for strength. I plan to cut balsa for model airplanes to start. Other things will be done later so the need for strength.
    Thanks for the help.
    Don
  3. phil from seattle
    phil from seattle Journeyman
    Take a look at bCNC.
  4. David the swarfer
    I use both bCNC and OpenbuildsCONTROL on my Xubuntu notebook.
    I transfer gcode files to it via Wifi. no problem.
