Control board for Mach 3 & Mach 4
Discussion in 'Controller Boards' started by Tom Sanders, May 28, 2017.
  1. Tom Sanders
    what are my best options for a control board for Mach 3 or 4 I have been using a arduino and GRBL to this point but would like to use Mach software it seems to be more of a standard.
  2. Rob Blaauw
  3. Joe Santarsiero
    Joe Santarsiero OB addict
  4. Rob Blaauw
    Thanks for the link the have a lot of interesting products.
  5. Tom Sanders
    Ok thanks for the info, do you recommend going parallel or usb?
  6. Tom Sanders
    Ok great thanks for the reply!!!!
    I just seems so confusing on which board to buy???? I want good board that is reasonable priced that will work with Mach 3 or Mach 4 and there are so many options out there....
    Do you have any idea what a majority are using?
  7. Tom Sanders
    Ok, so do you recommend any usb control board?
  8. Joe Santarsiero
    I've read enough gripes against noisy usb cables that it turned me to Ethernet to LPT. The downside is that I had to use a seperate power supply for 5V to the board. I just put a little 5V wallwart in the control cab. An upside is that I'm not limited by usb cable length.
  9. Tom Sanders
    Ok that makes sense!! What Ethernet board do you have?
  10. Joe Santarsiero
    I use a warp9 ess. little pricey though. I think there are a few others out there that are decent too. BTW, this is an extra device between the PC and the break out board.
  11. Tom Sanders
    Ok thanks for getting back with me! The breakout board is where your steeper drivers plug in right?
  12. Joe Santarsiero
    Yes. The BOB sends and receives signals. So, limits, e-stop, ssr, spindle control, etc all interface with the BOB. Some BOB's are basic and straightforward others are feature rich.
    Draw yourself a block diagram of all the components and connections you are going to have to determine if a BOB will work for you.
  13. Tom Sanders
    Ok at this point I have been using a Arduino board and my drivers plug right into it.
    So with the setup your talking about, I will need the Ethernet Controller, BOB, and then my drivers hooked to my stepper motors right?
  14. Joe Santarsiero
    Yes. What drivers and power supply?
  15. Tom Sanders
  16. Joe Santarsiero
  17. Tom Sanders
    Ok so 48v is better? More power?
    I assume the drivers will still work with the 48v power supply
  18. Joe Santarsiero
    The drivers are rated up to 48v. The motors will be a bit snappier than at 24v because of faster current delivery. Power is voltage times current so in a sense..yes. more power :)
  19. Tom Sanders
    Ok makes sense! So if you use the warp9 ess controller what BOB do you use?
  20. Joe Santarsiero
    I use a driver breakout combination. My BOB is built into a common box as the drivers. It's similar to the Gecko G540.
    Leadshine MX4660 4-Axis Stepper Motor Drive with I/O's
    You'll notice it has two port connections. A LPT and a DB26(basically a 26pin lpt). They're both connected to 2 of the 3 db26 ports of the ESS and their pins are assigned by me in the Mach software. For a future project I plan on utilizing the 3rd db26 port of the ESS to an analog MPG controller. Then I will assign db26 connection pins in Mach. I want to optically isolate the MPG instead of hardwiring it directly to the ESS.
