constant re-homing between each job?
Discussion in 'Controller Boards' started by Mel Ristau, Sep 6, 2015.
  1. Mel Ristau
    Have upgraded TinyG firmware but still unable to run a series of jobs without re-setting board, re-homing and re-G92ing. If I run a Vectric cut2d file (like below) twice, without rebooting board, on second run z axis moves up until trips limit switch. Any suggestions?
    G90
    G17
    G20
    G64
    G0Z0.5010
    G0X0.0000Y0.0000
    M3 S18000
    G0X5.1247Y3.1676Z0.5000
    G1Z-0.0625F10.0
    G1X5.1399Y3.1467F20.0
    X5.1512Y3.1394
    Etc.
    G2X4.9541Y1.6791I0.2011J0.1703
    G2X4.9218Y1.7697I0.4751J0.2203
    G1X4.9123Y1.8096
    X4.8714Y1.9615
    G3X4.7647Y2.2173I-1.5145J-0.4813
    G3X4.4715Y2.5860I-1.1083J-0.5804
    G0Z0.5000
    G0Z0.5010
    G0X0.0000Y0.0000
    M30
  2. John Meikrantz
    John Meikrantz Well-Known
    I believe what you are seeing is expected behavior with G92 zeroing.
    G92 is a "temporary" offset, and wiped out by the M30 at the end of your gcode. To set zero coordinates, you should probably be using G10 L2 P1 X0 Y0 Z0 instead of the G92 command.
    Coordinate system reference for TinyG - https://github.com/synthetos/TinyG/wiki/Coordinate-Systems
    I had the same issue when starting out with Grbl. Good discussion of the issue that is Grbl oriented, but explains well. https://github.com/grbl/grbl/issues/155
    -- John
  3. John Meikrantz
    I should add that TinyG has added a few "nonstandard" gcodes to simplify this - G28.2 and G28.3
    -- John
  4. Mel Ristau
    Understand now. Thanks for pointers John!
