Connected OB Control to another mac computer and it wont run gcode file
Discussion in 'Control Software' started by cjc0306, Apr 18, 2022.
  1. cjc0306
    cjc0306 New
    I connected my mac-book pro to the OB Control with no issues, and can run files with no problem. I decided to connect my 1515 to my Imac desktop and OB Control will not initiate the gcode file. I can connect and jog/home the machine just fine, but when I run a file it just stalls with no response. I tried resetting the computer and the software, but no luck. What could be the issue?
    a particular file or any file?
  3. cjc0306
    cjc0306 New
    Any file, tried 3 different ones.
    CONTROL allowed through the local Mac firewall? Jogs = websocket, Run Jobs = http post (Websockets has a size limit, cannot use it to transfer large gcode files between frontend and backend)
  5. cjc0306
    cjc0306 New
    Hi Peter,
    What is the solution, to increase the websocket size limit?
    No, I am just telling you a little about what's under the hood. The real question was:
  7. cjc0306
    cjc0306 New
    Yes, Control is allowed thru firewall.
    MacOS versions the same?
    CONTROL versions the same?
    No clues in Serial Terminal log?
  9. cjc0306
    cjc0306 New
    Solution: I had a software registration issue on the other computer. Meshcam would not produce a printable file until I registered both computers. Thanks for the help!
