Co2 Laser cutter/engraver using the OpenBuilds BlackBox
Discussion in 'Laser Cutters' started by cranktown, Oct 1, 2021.
  1. Gareth90
    Gareth90 New
    ok cool ill to grab one
  2. Gareth90
    Gareth90 New
    the potentiometer is working fine because it will go from 0 to 4 ma
    and if i test it with L on the power supply i get 0 to 30+ Ma
    Great... BUT note what I also said earlier:
    As we know you did some weird wiring in the beginning, you'd need a multimeter to test that your BlackBox is working fine too
    If the BlackBox didn't pick up damage from the incorrect wiring - also remember you pumped 10v into a 5v input on the laser PSU - maybe you damaged your H input.
  4. Gareth90
    Gareth90 New
    The black box is fine so I’ll put it on eBay
    As I got a Ruida rdc6445g/s I like the dap controller
