CNC Xpro v5 motors not turning
Discussion in 'Controller Boards' started by richard yates, Aug 12, 2021.
  1. richard yates
    I have the Xpro V5 running 4 stepper in an XYYZ configuration. It was working on a previous machine with the same stepper motors. I purchased a workbee and transferred all of the electronics and motors over to it and now I can't get any motion at all.
    I am fairly new to this and could use some troubleshooting advise.
    Also the motors are not getting hot at all and they are not locking up.
    Here is the GRBL settings:
    $0=10
    $1=255
    $2=7
    $3=0
    $4=0
    $5=1
    $6=1
    $10=3
    $11=0.020
    $12=0.002
    $13=0
    $20=0
    $21=1
    $22=1
    $23=1
    $24=1500.000
    $25=1500.000
    $26=25.000
    $27=2.500
    $30=2500.000
    $31=0.000
    $32=0
    $N1=
    $N0=
    $100=201.027
    $101=201.027
    $102=201.027
    $103=200.000
    $104=100.000
    $105=100.000
    $110=1500.000
    $111=1500.000
    $112=1000.000
    $113=1000.000
    $114=1000.000
    $115=1000.000
    $120=150.000
    $121=150.000
    $122=300.000
    $123=200.000
    $124=200.000
    $125=200.000
    $130=800.000
    $131=450.000
    $132=100.000
    $133=300.000
    $134=300.000
    $135=300.000
    #1 richard yates, Aug 12, 2021
    Best to contact the vendor you purchased the controller from for tech support. Thanks
  3. Giarc
    From your vendor:
    Are you using the proper grbl flavor? I assume you are since you just moved everything over, but the V5 xpro is pretty new, so just checking.
  4. richard yates
    It is running GRBL 1.3
    Diagnostic shows motors are not getting power
  5. Gary Caruso
    4=1
    worked for the v4 at least
  6. richard yates
    ok I will try that , thank you
