CNC xPRO v3 cloned axis dropping out
Discussion in 'Controller Boards' started by jaserules, Jan 2, 2017.
  1. jaserules
    jaserules New
    I am having problems with the cloned y axis dropping off randomly, this is a new ox build and ive been trying to work it out and am yet to do my first successful test piece.
    ive tried upping the current draw and slowing down the speed but nothing seems to make a difference
    Ive swapped the two motor outputs over and the other motor stops so to me this confirms it is on the cloned output and not motor related, Not sure on where to go from here as its frustrating
    made a short video to help try explain, excuse the ums :D i paused it mid way and went to start it to show it not working but it actually came right and worked ok (usually a full power reset is required ) but you can see near the end the slave axis leds do not go and you can briefly hear the master y axis motor go but see not the clone
    video link
    also the wiring is correct I just had to lengthen it, have also used shielded cable
    any help or advice appreciated.
    thanks
  2. T.C. Mabe
    T.C. Mabe New
    We are having the same exact issues as described here. We have also swapped motor leads and tested each motor individually. Any help would be appreciated.
  3. jaserules
    jaserules New
    Contact the manufacturer. They got me to try some tests and then sent out a new board. I sent the old one to them to test . New board works a treat . Sorry don't have my computer at the moment but if you need the contact message me and I'll get it when I get home .
  4. T.C. Mabe
    T.C. Mabe New
    Thanks for the follow-up. I should be able to locate the manufacturer and go through the return process. Thanks again !
  • About Us
    [email protected]
  • Follow us on Instagram
    Donate to Open Source
