CNC xPro & 'grbl Controller' (Zapmaker) software incompatibilities?
Discussion in 'Controller Boards' started by Chillimonster, Jan 26, 2016.
  1. Chillimonster
    Chillimonster Well-Known
    While i wait for my kit to be delivered i'm going to be 'playing' with software options to control the CNC xPro.
    Originally i was going to run a PC in the workshop but thought about using a raspberry Pi (Connected to a monitor, with keyboard and mouse) due to size etc.
    I notice that GRBL controller is not recommended for the CNC xPro on the Ooznest Site - is this still the case - what are the issues running this combo?
    If thats a no-go what are the alternatives for a self contained solution (No internet in workshop)?
    I used to use Mach3 on my Stepcraft, but as that is not compatible..........
    Any help is appreciated.
  2. John Meikrantz
    John Meikrantz Well-Known
    My two favorites right now are bCNC and cnc.js. I have a similar setup with Raspberry Pi in the workshop connected to control CNC.
    GitHub - cheton/cnc.js: CNC.js is a web-based CNC milling controller for the Arduino running GRBL.
    vlachoudis/bCNC: GRBL CNC command sender, autoleveler and g-code editor
  3. Chillimonster
    Thanks John
    The Pi route makes sense as i have quite a few of them as i use them in my Arcade machines and they are small, and rock solid in use, and dont want a big power hungry PC serving the CNC machine when i can 'get away' with something smaller.
  4. daisosasen01
