CNC X PRO v3 E-Stop jumper
Discussion in 'Controller Boards' started by KFC, May 1, 2017.
  1. KFC
    KFC New
    I am in the process of wiring up my Ooznest Big-Ox router and have come across a problem trying to wire the e-stop button. The documentation for the board shows the v2 model which incorporates a soldered jumper that has to be desoldered in order to make the button work, but the v3 model does not have that same jumper. Does anyone know how to wire up the e-stop button for the v3 board?
  2. Ryan Lock
    Ryan Lock Veteran
    Hi,
    This is only if you have an ATX PSU, are you using one of them? If so @Michael should be able to help you out.
    Ryan
