CNC work station
Discussion in 'CNC Mills/Routers' started by Fabio Ibarra, Jul 27, 2020.
  1. Fabio Ibarra
    Hi there!
    I have just purchased a Workbee 1510 and am planning to build a workstation to install my machine.
    I would like to ask those who have experience with the 1510 and consult them. What material do you consider most appropriate for the table? Metal frame or plywood? I plan to machine wood, aluminum and plastics.
    I would appreciate comments.
    Greetings from Paraguay
  2. JustinTime
    JustinTime Veteran
    Plywood will work fine. Many have built their tables, including me, from plywood. If you have access to metal working tools and are more comfortable with metal then by all means do it in metal.
    Fabio Ibarra likes this.
  3. Fabio Ibarra
    Great! Thank you for your comment. I have access to a metal workshop but I have the doubt if a metal frame tablet It Will be a overkill for a workbee 1510
  4. Giarc
    I built a torsion box table top for mine out of particle board it is extremely flat, dimensionally stable, and heavy so it helps reduce vibrations.
  5. Fabio Ibarra
    Awesome! Thank you for your comment.
