CNC Router Design: Custom Gantry Plates vs Standard Plates Plus Extrusion
Discussion in 'General Talk' started by Jonathon Duerig, May 21, 2016.
  1. Jonathon Duerig
    Jonathon Duerig Journeyman
    Browsing through the designs here and elsewhere (OX, shapeoko, CNC router parts, etc.) there seems to be a basic commonality to all of them: the use of custom gantry plates. The plates have various holes for mounting wheels, motors, linear guide, and usually a pattern of holes for mounting the tapped holes of extrusion for the cross beam.
    I've been toying with a couple of design ideas that use just 'standard' gantry plates instead. One or two C-Beam gantry plates attached to 20x40 extrusion. Then any cross beams can rest on the extrusion attached with as many attachment plates/brackets as I want on the sides or the bottom so it is secure.
    The disadvantage is that there are more pieces. But you end up with a 'plate' that is 20mm thick. You can tighten the screws into steel T-nuts rather than easily stripped and tricky to tap aluminum end holes. And overall it seems easier to make a wider gantry for more wheels and stability if needed.
    What do you think? Are there any hidden gotchas here? When is it better to use custom plates and when is it better to use the cheaper 'standard' plates?
    -D
  2. TerryOx
    TerryOx Well-Known
    Show us an example please.
  3. Jonathon Duerig
    One example is how I built the gantry for my CNC glass grinder. I attached a single piece of extrusion to two different standard C-Beam gantry plates which gave it a very wide base of support and 8 wheels. You can see the crosswise piece of aluminum in this shot:
    http://openbuilds.com/attachments/photo-feb-16-6-57-25-pm-jpg.14198/
    Another example is shown on the parts store where they have a sample build for the double wide gantry plate:
    http://cdn1.bigcommerce.com/server2...ide_Plate__20877.1458424233.1280.1280.jpg?c=2
    Here they show the z-axis C-beam held onto a double wide gantry plate by black corner brackets instead of having custom y-axis or z-axis gantry plates.
    I've been thinking, why not do a router entirely this way? Instead of using OX plates, some other plates, or designing my own. Has anyone built a cnc router just out of standard parts from the parts store without custom gantry plates?
    -D
  4. Rick 2.0
    If you go way back to the original Routy, it was done without any custom plates. It has since been updated a bit but still has the same potential issues. The thin plates are a bit too flexible when you start trying to scale up the capabilities and tacking plates on plates is a bit inefficient. The custom plates used on the Ox and subsequent systems were a response to eliminating the thin plates and the inefficient use of parts. This however created issues with availability.
    But all this was in the past and things have evolved a fair amount over the past two years. The newest plate C-Beam™ Gantry Plate - XLarge resolves a lot of those issues and now provides a solution to building fairly stout routers without custom plates as shown in Mark's most recent design shown here.
    Mark Carew, MaryD and Kyo like this.
