Project CNC project using UNO R3 and Adafruit Shield L293D
Discussion in 'CNC Projects' started by Bobrhamuela, Aug 23, 2016.
  1. Bobrhamuela
    Hi, to all I have started a CNC project using UNO R3 and Adafruit Shield L293D.
    Here is my equipment:
    Arduino UNO R3
    Adafruit shield Motor L293D 5 - 25 V dc capacity
    Stepper Motor NEMA 17, 5 - 12 Vdc
    Stepper Motor 0404A 24.2 V dc
    External PWR supply 24 Vdc
    Software used:
    Arduino 1.6.11
    Grbl 0.9j
    Universal Gcode Sender 1.0.9
    Issues:
    When I used the arduino multiple stepper testing from the arduino library, the 2 motors is working fine. But when I used the Universal Gcode Sender, motor is not responding at all. Everything is working fine from Arduino to Grbl.
    Please see attached file.
  2. jlbruni
    jlbruni New
    Hello! I'm new to the forum. You could send information about the software you use?
  3. Bobrhamuela
    Hi, I am using Universal Code sender v 1.0.9, Grbl o.8c.
  4. jlbruni
    jlbruni New
    Thanks you!
    Best regard,
    José Luis
