CNC Pro V.3 board
Discussion in 'Controller Boards' started by Tony Pagett, Jul 14, 2018.
  1. Tony Pagett
    What do the different LED's on the cnc xPro board mean?
    I get a mix of either red, green or both on each axis but it seems that they are not consistent.
    For example:
    If I home my machine I might get X=green, Y= green and Z=red
    But another time I home I get X=red, Y=red and Z=red/green
  2. bubba
    bubba New
    The LED changes colour based on the direction the stepper is rotating.
  3. Tony Pagett
    I think I must have a fault on my board then. The colours are totally random
  4. Gary Caruso
    Tony
    Is it working or no?
    Gary
  5. Tony Pagett
    It has started playing up on the x axis. The axis stops but the others carry on running
  6. Gary Caruso
    Tony,
    Probably heat related, hows your cooling?
    Did you make sure all your motor connections are tight?
    Gary
  7. Tony Pagett
    I have two fans for cooling. I have turned the trim pot down a small amount to see if this helps.
    I currently have it running a test pattern and (touch wood) all seems well
