CNC Plasma cuter
Discussion in 'Other Builds' started by Serhioormano, Mar 24, 2015.
  1. Serhioormano
    I am building CNC Plasma Cuter. But it looks like here there is no section dedicated for that. Is that because it is not suitable?
    I want to use openbuilds to create my plasma cuter table. But instead of timing belt I'll use gear rack mounted along 20x40 and 3:1 timing conversion kit.
    The size of the table will be out of 30x40 square tubing and cutting surface 1200mm x 2200mm.
    Do you think I can build reliable precision, durable CNC plasma cuter with openbuilds?
  2. HeartMan
    HeartMan New
    I am building a CNC Plasma Cutter myself. I am considering what to use for the linear motion rails. I have been told that Plasma Cutters produce a great deal of metal dust. I am wondering if anyone has recommendations about what type of Openbuilds rails and wheels would be best for this environment. I am concerned that the dust collecting on the wheels and rails might cause tracking problems and/or unusual wear. The plans that I purchased utilizes V-Wheels on a V-Rail. I think that the Openbuilds material will produce better stability if they can deal with the metal dust.
  3. Serhioormano
    I was investigating it and I found out that for plasma timing belt is ok. I'll use G3. It will be even good for router on wood and plastic.
    I do not think dust will be a problem. I am planing to use little bit of silicon lubricant.
  4. Justin Christensen
    Check out this video
    GrayUK likes this.
